I cannot add all the result cause there are a lot of links...
  404  Not Found [IP: 200.236.31.4 80]
Ign:109 http://br.archive.ubuntu.com/ubuntu focal-backports/universe arm64 Packages
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/pypa/ppa/ubuntu jammy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: https://dl.winehq.org/wine-builds/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://dl.winehq.org/wine-builds/ubuntu jammy InRelease' doesn't support architecture 'arm64'
And for sudo apt-get update:
It seems that you are using the Wine repository, but have an ARM processor, which the repository does not support.
So, open Software & Updates, and remove that repository in the list of Other Software.
Also, you there is a warning due to the pypy PPA, and it does support your version of Ubuntu for ARM. Try removing that PPA, and add the PPA once again.
Run the command
sudo add-apt-repository --remove ppa:pypy/ppa
sudo add-apt-repository ppa:pypy/ppa
