-3
I accidentally deleted my ubuntu desktop and now I have no way of redownloading it. I’ve tried to do a sudo apt update and upgrade. When I type
Sudo apt install ubuntu-desktop
I get the following issue: Package ‘Ubuntu-desktop’ has no installation candidate. I tried everything including deleting the list file, cleaning, updating, upgrading, etc. please help
Version: Ubuntu 21.10
aqwertya
  • 112
Ubuntu 21.10 (Impish Indri) End of Life reached on July 14 2022.
Ubuntu 21.10 is no longer supported. It is archived to old-releases.ubuntu.com. You have edit /etc/apt/sources.list and change 'archive.ubuntu.com' to 'old-releases.ubuntu.com'.
This can be done by typing
sudo sed -i -e 's/archive.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
in the terminal. After running this command, run sudo apt update && Sudo apt install ubuntu-desktop. It is best you update to a newer and supported version of Ubuntu unless you have a very specific and genuine reason to stay on Ubuntu 21.10.
aqwertya
  • 112
If you are trapped you can try installing an alternative DE like cinnamon or KDE. To install KDE use the following command
sudo apt install kde-plasma-desktop
or you can upgrade your desktop using the command
sudo do-release-upgrade
Hope this helps you.
