we have an Ubuntu 20.04 which starts only with an TTY and no GUI.
After our customized /etc/issue is shown to the user the command prompt will be shown only for 30 seconds. The best solution should be that the login prompt should be shown forever.
The line looks like hostname login: _ where the underscore is blinking.
After 30 seconds the hostname login: disappears and only the blinking underscore stays: _.
After typing a username for example admin, password will be requested
admin
Password: _
I tried now to update the GRUB_TIMEOUT to -1 but no effect.
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=-1
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="autoinstall ds=nocloud-net;"
GRUB_CMDLINE_LINUX=""
Futher I found out that there is another place where a time out is set to 60 seconds in /etc/login.defs.
# Max time in seconds for login
# LOGIN_TIMEOUT 60
Disabling LOGIN_TIMEOUT had no effect.
Futher I checked /etc/systemd/logind.conf where I could find a place with 30 seconds but it was commented out.
HoldoffTimeoutSec=60s
Changing it to 60 second did not decrease the prompt time.
Does anybody know what can I do now?
Thanks, Markus
EDIT: The TTY seems to be 1
root 903 0.0 0.0 5828 1932 tty1 Ss+ 09:17 0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
journalctl -xe -u getty@tty1.service returns
Mai 17 09:17:38 hostname systemd[1]: Started Getty on tty1.
-- Subject: A start job for unit getty@tty1.service has finished successfully
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- A start job for unit getty@tty1.service has finished successfully.
Further I checked more /lib/systemd/system/getty@.service and more /lib/systemd/system/serial-getty@.service
I can not see a prompt timeout and have not done any changes.
I modified /etc/default/grub as recommanded and run sudo update-grub
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_CMDLINE_LINUX_DEFAULT="autoinstall consoleblank=0 ds=nocloud-net;"
But no behaviour change could be observed.
