I’m experiencing an issue with Byobu where non-standard escape sequences are being printed when I start a session. My prompt, which should display as andy@msi-ge62 ~, is surrounded by these sequences, appearing like this after launching Byobu:
^[[>0;10;1candy@msi-ge62 ~ 0;10;1c
It was working fine prior to today. I'm not sure what happened.
I am using Windows 11 command prompt as the terminal emulator. It doesn't seem to happen in some other terminal emulators, PUTTY for example. I have been using Windows command prompt because it's the only terminal in which all of the function keys work properly for me in Byobu.
I'm using:
- Byobu version 5.133
- tmux 3.2a
- Ubuntu Server 22.04.
- Client is Windows 11 22H2 (Build 22621.1702)
I can't replicate this issue on other Linux hosts with Byobu using the same Windows terminal emulator.
Here's what I've tried so far to resolve the issue:
- Checked the TERM environment variable outside of Byobu. It's set to xterm-256color.
- Reset Byobu's configuration by renaming the ~/.byobu directory. This didn't change the behavior.
- Used a clean .bashrc.
- My shell's PS1 configuration seems to be normal.
- Uninstalled and purged tmux and Byobu then reinstalled them both fresh.
I'm unsure of how to proceed with troubleshooting this issue. Any guidance would be greatly appreciated.
