Im having some issue after updating ubuntu from v20 to v22, and i really need your help.
I surely messed up some python files, and now the vast majority of 'apt' command wont work at all.
Since i already had problems with my ubuntu-desktop, i though i would reinstall it. Problem is, it did uninstall properly, but i can't install it, i always get the same python error :
python3 : Depends: libpython3-stdlib ( = 3.10.11-1+focal1) but it is not going to be installed
python3.10 : Depends: libpython3.10-stdlib (= 3.10.11-1+focal1) but it is not going to be installed
python3.10-minimal : Depends : libpython3.10-minimal (=3.10.11-1+focal1) but it is not going to be installed```
Basically, i've tried everything i could come across online.
Not any apt/apt-get/purge/autoremove/fix-broken,... command work add-apt-repository is broken too
So now im basically stuck on a CLI only ubuntu that can't install anything, and i really don't have a clue on what to do.
While trying to restore my computer I might have messed it up even more than it was, and i might have multiple python installed now, but im not even sure how to check on that.
laptel
One method: Back up your data, then clean-install Ubuntu 22.04.
"i've tried everything i could come across online" is too vague to understand what you might have done, and a reinstall will be much faster for most folks than the troubleshooting that you don't know how to do anyway.
Going forward, there are two safe ways to have different versions of Python co-exist without destroying your system. You should master at least one of them. It's too late to use them on your current system -- the damage is already done.
  1. Virtualization
  2. Proper use of update-alternatives
user535733
  • 68,493
Before you try this make a backup of your important data and make a propper install media for jammy!
mkdir $HOME/backup/
Then we move sources.list's from foreign packages sources in this folder.
sudo mv /etc/apt/sources.list.d/* $HOME/backup/
Then we make a backup from your old sources.list.
sudo mv /etc/apt/sources.list /etc/apt/sources.list.bak
Create a new one
deb http://archive.ubuntu.com/ubuntu jammy main restricted
deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted
deb http://archive.ubuntu.com/ubuntu jammy universe deb http://archive.ubuntu.com/ubuntu jammy-updates universe
deb http://archive.ubuntu.com/ubuntu jammy multiverse deb http://archive.ubuntu.com/ubuntu jammy-updates multiverse
deb http://archive.ubuntu.com/ubuntu jammy-security main restricted deb http://archive.ubuntu.com/ubuntu jammy-security universe deb http://archive.ubuntu.com/ubuntu jammy-security multiverse deb http://archive.canonical.com/ubuntu jammy partner
When we try over apt pinning to force packages to jammy version. Create
sudo nano /etc/apt/preferences.d/jammy.pref
with following content.
Package: *
Pin: release n=jammy
Pin-Priority: 1001
Refresh package cache
sudo apt update
First a simulation from partial upgrade Note this is the debian way.
apt -s upgrade
Check the output carefully. If apt tells you are doing something dangerous (remove essential packages) Stop. And install anew like @user535733 told.
If no errors
sudo apt upgrade
Then next simulation
sudo apt -s full-upgrade
Check the ouput again before you make the command for real.
sudo apt full-upgrade
Note this is a dangerous attempt to fix your installation. That's why it is so important to make a backup before and a functional install media.
nobody
  • 5,792
