When I recently upgraded to Ubuntu 23.04 from 22.10, I was unable to start Emacs (I am using Doom Emacs). In the terminal I get this message:
emacs: error while loading shared libraries: libtiff.so.5: cannot open shared object file: No such file or directory
Note that under 22.10, I had built and installed Emacs 28.2. I have tried simply installing Emacs 28.2 which now is packaged for Ubuntu 23.04 but that does not work. I also tried creating a symlink between libtiff.so.5 and libtiff.so.6 as suggested by someone (can't find the link now), but again that did not change anything.
Do I need to rebuild and reinstall Emacs under 23.04, or should I completely remove my existing Emacs and Doom and reinstall using apt-get? Or is there something else I should be doing?
I am very much a newbe playing with things I don't really understand, so your help would be appreciated.
David
  • 53
I think Ubuntu 23.04 ships with libtiff.so.6; double-check that this is correct by looking in /usr/lib/x86_64-linux-gnu.
If the particular APIs that Emacs uses in libtiff haven't changed then you can fool Emacs by creating a symlink named libtiff.so.5 to libtiff.so.6.
In /usr/lib/x86_64-linux-gnu run something like sudo ln -s libtiff.so.6 libtiff.so.5.
Had similar issue when working with CARLA 0.9.10.1 PythonAPI that stopped working when I upgraded ubuntu.
I manged to resolved creating a symlink to the new version:
cd /usr/lib/x86_64-linux-gnu/
Note: This solution does not apply to Doom Emacs and should probably be under a much more general question, but this is what solved my emacs upgrade error which complained about libtiff.so.5:
Wow! I performed an upgrade against emacs-gtk and met this error. Applying the accepted solution, proved that this error was only the tip of the ice-burgh. So I did this:
  1. Remove emacs via apt-get purge emacs*
  2. Remove any executable that appears in emacs code completion.
  3. Download, compile, and install emacs from source.
It is unusual that I download any emacs Debian package, but I performed a hurried install last time around when I installed emacs-gtk.
Long ago, I created a routine to compile emacs because it enables emacs automated help to display corresponding source code even if C.
zDir=$(dirname -- "${BASH_SOURCE[0]}")
zSource="$zDir/emacs"
if [[ -d "$zSource" ]]; then
    cd "$zSource"
    git pull --rebase # should I use --rebase?
else
    cd "$zDir" || exit 1
    git clone https://salsa.debian.org/rlb/deb-emacs.git "$zSource"
    cd "$zSource" || exit 1
fi
emacs is deeply connected to x
sudo apt-get -y build-dep emacs-gtk
./autogen.sh # create configure+x according to configure.ac ./configure # create Makefile according to Makefile.in
existing files are not removed by git pull pull --rebase
make clean does not remove old .elc files which will case make to fail
find "$zSource" -name '*.elc' -exec sudo rm '{}' +
make sudo make install # did this instead of make-dist and it worked
cd -
Paul
  • 430
