Err:10 https://ppa.launchpadcontent.net/webupd8team/y-ppa-manager/ubuntu kinetic Release
  404  Not Found [IP: 185.125.190.52 443]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/webupd8team/y-ppa-manager/ubuntu kinetic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Nmath
  • 12,664
Looks like a PPA you are using is not compatible with the new version.
If you are using the software updater to do the upgrade (on desktop ubuntu) then it should guide you through what to do when you encounter this eg ppa-purge, not just by removing the ppa or packages.
It's generally recommended to remove software from PPAs prior to an upgrade, or at the minimum, verify with the PPA maintainer whether it is compatible with the new ubuntu version.
thomasrutter
  • 37,804
