I can't save things because there is no disk space left.
I am a complete novice, please can someone tell me what is wrong, or what other information I should provide?
Is my computer just FULL now?
Is there something wrong with snap? I don't really know what snap is.
Many processes cannot complete.
Saving is often not possible in one application until I close all other applications.
I have deleted a lot of software and also run everything I can Google in the Terminal! Output is pasted below:
(I checked inodes at the end too)
talyadavies@talyadavies-E201NAS:~$ sudo du -sh
30G .
talyadavies@talyadavies-E201NAS:~$ sudo df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.9G 0 1.9G 0% /dev
tmpfs 381M 1.7M 380M 1% /run
/dev/mmcblk0p2 57G 54G 0 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/loop0 19M 19M 0 100% /snap/chromium-ffmpeg/30
/dev/loop2 324M 324M 0 100% /snap/kde-frameworks-5-qt-5-15-core20/14
/dev/loop1 9.2M 9.2M 0 100% /snap/python38/22
/dev/loop3 165M 165M 0 100% /snap/gnome-3-28-1804/194
/dev/loop5 461M 461M 0 100% /snap/gnome-42-2204/99
/dev/loop4 377M 377M 0 100% /snap/digikam/70
/dev/loop6 56M 56M 0 100% /snap/core18/2721
/dev/loop7 37M 37M 0 100% /snap/nikola/252
/dev/loop8 141M 141M 0 100% /snap/gnome-3-26-1604/104
/dev/loop9 128K 128K 0 100% /snap/bare/5
/dev/loop11 165M 165M 0 100% /snap/gnome-3-28-1804/198
/dev/loop22 449M 449M 0 100% /snap/kf5-5-104-qt-5-15-8-core22/9
/dev/loop14 242M 242M 0 100% /snap/firefox/2579
/dev/loop16 38M 38M 0 100% /snap/hunspell-dictionaries-1-7-2004/2
/dev/loop15 5.2M 5.2M 0 100% /snap/eog/706
/dev/loop17 219M 219M 0 100% /snap/gnome-3-34-1804/93
/dev/loop18 64M 64M 0 100% /snap/core20/1852
/dev/loop13 350M 350M 0 100% /snap/gnome-3-38-2004/137
/dev/loop12 155M 155M 0 100% /snap/brave/232
/dev/loop10 117M 117M 0 100% /snap/core/14784
/dev/loop21 78M 78M 0 100% /snap/easy-disk-cleaner/43
/dev/loop20 323M 323M 0 100% /snap/wine-platform-6-stable/19
/dev/loop19 242M 242M 0 100% /snap/firefox/2605
/dev/loop25 438M 438M 0 100% /snap/kde-frameworks-5-98-qt-5-15-6-core20/9
/dev/loop28 73M 73M 0 100% /snap/core22/617
/dev/loop33 219M 219M 0 100% /snap/gnome-3-34-1804/90
/dev/loop31 239M 239M 0 100% /snap/digikam/55
/dev/loop29 28M 28M 0 100% /snap/chromium-ffmpeg/28
/dev/loop35 45M 45M 0 100% /snap/nikola/1739
/dev/loop23 82M 82M 0 100% /snap/gtk-common-themes/1534
/dev/loop24 56M 56M 0 100% /snap/core18/2714
/dev/loop27 154M 154M 0 100% /snap/brave/228
/dev/loop26 141M 141M 0 100% /snap/dbtarzan/19
/dev/loop30 5.3M 5.3M 0 100% /snap/eog/708
/dev/loop32 437M 437M 0 100% /snap/kde-frameworks-5-96-qt-5-15-5-core20/7
/dev/loop34 449M 449M 0 100% /snap/kf5-5-105-qt-5-15-9-core22/5
/dev/loop36 1.1G 1.1G 0 100% /snap/libreoffice/272
/dev/loop37 449M 449M 0 100% /snap/kf5-5-104-qt-5-15-8-core22/7
/dev/loop38 117M 117M 0 100% /snap/core/14946
/dev/loop40 347M 347M 0 100% /snap/wine-platform-runtime/343
/dev/loop39 350M 350M 0 100% /snap/gnome-3-38-2004/140
/dev/loop41 141M 141M 0 100% /snap/gnome-3-26-1604/111
/dev/loop42 1.1G 1.1G 0 100% /snap/libreoffice/275
/dev/loop43 141M 141M 0 100% /snap/dbtarzan/18
/dev/loop44 425M 425M 0 100% /snap/kde-frameworks-5-qt-5-15-3-core20/8
/dev/loop45 73M 73M 0 100% /snap/core22/607
/dev/loop46 64M 64M 0 100% /snap/core20/1828
/dev/loop47 92M 92M 0 100% /snap/gtk-common-themes/1535
/dev/loop48 461M 461M 0 100% /snap/gnome-42-2204/87
/dev/mmcblk0p1 511M 6.1M 505M 2% /boot/efi
tmpfs 381M 44K 381M 1% /run/user/1000
talyadavies@talyadavies-E201NAS:~$ sudo lsof | grep deleted
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
Output information may be incomplete.
xfdesktop 1410 talyadavies 15r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
xfdesktop 1410 talyadavies 16r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
gmain 1410 1414 talyadavies 15r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
gmain 1410 1414 talyadavies 16r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
gdbus 1410 1415 talyadavies 15r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
gdbus 1410 1415 talyadavies 16r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
pulseaudi 1526 talyadavies 6u REG 0,5 67108864 32654 /memfd:pulseaudio (deleted)
alsa-sink 1526 1563 talyadavies 6u REG 0,5 67108864 32654 /memfd:pulseaudio (deleted)
alsa-sour 1526 1564 talyadavies 6u REG 0,5 67108864 32654 /memfd:pulseaudio (deleted)
snapd-gli 1526 1573 talyadavies 6u REG 0,5 67108864 32654 /memfd:pulseaudio (deleted)
gnome-sof 2362 talyadavies 20r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
gnome-sof 2362 talyadavies 21r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
gmain 2362 2363 talyadavies 20r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
gmain 2362 2363 talyadavies 21r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
gdbus 2362 2364 talyadavies 20r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
gdbus 2362 2364 talyadavies 21r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
dconf\x20 2362 2365 talyadavies 20r REG 179,2 19732 264111 /home/talyadavies/.local/share/gvfs-metadata/root (deleted)
dconf\x20 2362 2365 talyadavies 21r REG 179,2 32768 264561 /home/talyadavies/.local/share/gvfs-metadata/root-dbcec989.log (deleted)
talyadavies@talyadavies-E201NAS:~$ sudo apt-get autoclean
Reading package lists... Done
Building dependency tree
talyadavies@talyadavies-E201NAS:~$ sudo apt-get autoremove
The following packages will be REMOVED
bogofilter bogofilter-bdb bogofilter-common evolution-common evolution-data-server evolution-data-server-common libcamel-1.2-61 libchamplain-0.12-0 libchamplain-gtk-0.12-0 libcryptui0a
libebackend-1.2-10 libebook-1.2-19 libebook-contacts-1.2-2 libecal-1.2-19 libedata-book-1.2-25 libedata-cal-1.2-28 libedataserver-1.2-23 libedataserverui-1.2-2 libevolution libgail-3-0
libgeocode-glib0 libgnome-autoar-0-0 libgnome-autoar-gtk-0-0 libgsl23 libgslcblas0 libgtkspell3-3-0 libgweather-3-15 libgweather-common libphonenumber7 libprotobuf10 libpst4 libytnef0
seahorse-daemon
0 to upgrade, 0 to newly install, 33 to remove and 2 not to upgrade.
1 not fully installed or removed.
After this operation, 51.4 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 272475 files and directories currently installed.)
Removing bogofilter (1.2.4+dfsg1-12) ...
Removing bogofilter-bdb (1.2.4+dfsg1-12) ...
Removing bogofilter-common (1.2.4+dfsg1-12) ...
Removing libevolution (3.28.1-2) ...
Removing evolution-common (3.28.1-2) ...
Removing evolution-data-server (3.28.5-0ubuntu0.18.04.3) ...
Removing libedataserverui-1.2-2:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libedata-cal-1.2-28:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libebook-1.2-19:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libchamplain-gtk-0.12-0:amd64 (0.12.16-2) ...
Removing libchamplain-0.12-0:amd64 (0.12.16-2) ...
Removing libcryptui0a:amd64 (3.12.2-5) ...
Removing libedata-book-1.2-25:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libebackend-1.2-10:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libebook-contacts-1.2-2:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libecal-1.2-19:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing libgail-3-0:amd64 (3.22.30-1ubuntu1) ...
Removing libgweather-3-15:amd64 (3.28.1-1) ...
Removing libgeocode-glib0:amd64 (3.25.4.1-4) ...
Removing libgnome-autoar-gtk-0-0:amd64 (0.2.3-1ubuntu0.4) ...
Removing libgnome-autoar-0-0:amd64 (0.2.3-1ubuntu0.4) ...
Removing libgsl23:amd64 (2.4+dfsg-6) ...
Removing libgslcblas0:amd64 (2.4+dfsg-6) ...
Removing libgtkspell3-3-0:amd64 (3.0.9-2) ...
Removing libgweather-common (3.28.1-1) ...
Removing libphonenumber7:amd64 (7.1.0-5ubuntu5) ...
Removing libprotobuf10:amd64 (3.0.0-9.1ubuntu1.1) ...
Removing libpst4:amd64 (0.6.71-0.1) ...
Removing libytnef0:amd64 (1.9.2-2) ...
Removing seahorse-daemon (3.12.2-5) ...
Removing libedataserver-1.2-23:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Removing evolution-data-server-common (3.28.5-0ubuntu0.18.04.3) ...
Removing libcamel-1.2-61:amd64 (3.28.5-0ubuntu0.18.04.3) ...
Setting up grub-efi-amd64-signed (1.173.2~18.04.1+2.04-1ubuntu47.4) ...
dpkg: error processing package grub-efi-amd64-signed (--configure):
installed grub-efi-amd64-signed package post-installation script subprocess returned error exit status 255
Processing triggers for doc-base (0.10.8) ...
Processing 6 removed doc-base files...
Registering documents with scrollkeeper...
Processing triggers for man-db (2.8.3-2) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libglib2.0-0:amd64 (2.56.4-0ubuntu0.18.04.9) ...
Processing triggers for gnome-icon-theme (3.12.0-3) ...
Processing triggers for libc-bin (2.27-3ubuntu1.5) ...
talyadavies@talyadavies-E201NAS:~$ sudo df -ih
[sudo] password for talyadavies:
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 468K 594 468K 1% /dev
tmpfs 477K 1.1K 476K 1% /run
/dev/mmcblk0p2 3.7M 358K 3.3M 10% /
tmpfs 477K 1 477K 1% /dev/shm
tmpfs 477K 5 477K 1% /run/lock
tmpfs 477K 18 477K 1% /sys/fs/cgroup
/dev/loop0 18 18 0 100% /snap/chromium-ffmpeg/30
/dev/loop2 41K 41K 0 100% /snap/kde-frameworks-5-qt-5-15-core20/14
/dev/loop1 1.3K 1.3K 0 100% /snap/python38/22
/dev/loop3 28K 28K 0 100% /snap/gnome-3-28-1804/194
/dev/loop5 20K 20K 0 100% /snap/gnome-42-2204/99
/dev/loop4 9.9K 9.9K 0 100% /snap/digikam/70
/dev/loop6 11K 11K 0 100% /snap/core18/2721
/dev/loop7 7.7K 7.7K 0 100% /snap/nikola/252
/dev/loop8 27K 27K 0 100% /snap/gnome-3-26-1604/104
/dev/loop9 29 29 0 100% /snap/bare/5
/dev/loop11 28K 28K 0 100% /snap/gnome-3-28-1804/198
/dev/loop22 43K 43K 0 100% /snap/kf5-5-104-qt-5-15-8-core22/9
/dev/loop14 730 730 0 100% /snap/firefox/2579
/dev/loop16 443 443 0 100% /snap/hunspell-dictionaries-1-7-2004/2
/dev/loop15 1.9K 1.9K 0 100% /snap/eog/706
/dev/loop17 19K 19K 0 100% /snap/gnome-3-34-1804/93
/dev/loop18 12K 12K 0 100% /snap/core20/1852
/dev/loop13 18K 18K 0 100% /snap/gnome-3-38-2004/137
/dev/loop12 231 231 0 100% /snap/brave/232
/dev/loop10 13K 13K 0 100% /snap/core/14784
/dev/loop21 132 132 0 100% /snap/easy-disk-cleaner/43
/dev/loop20 2.7K 2.7K 0 100% /snap/wine-platform-6-stable/19
/dev/loop19 730 730 0 100% /snap/firefox/2605
/dev/loop25 42K 42K 0 100% /snap/kde-frameworks-5-98-qt-5-15-6-core20/9
/dev/loop28 14K 14K 0 100% /snap/core22/617
/dev/loop33 19K 19K 0 100% /snap/gnome-3-34-1804/90
/dev/loop31 7.4K 7.4K 0 100% /snap/digikam/55
/dev/loop29 24 24 0 100% /snap/chromium-ffmpeg/28
/dev/loop35 11K 11K 0 100% /snap/nikola/1739
/dev/loop23 75K 75K 0 100% /snap/gtk-common-themes/1534
/dev/loop24 11K 11K 0 100% /snap/core18/2714
/dev/loop27 231 231 0 100% /snap/brave/228
/dev/loop26 16K 16K 0 100% /snap/dbtarzan/19
/dev/loop30 1.9K 1.9K 0 100% /snap/eog/708
/dev/loop32 42K 42K 0 100% /snap/kde-frameworks-5-96-qt-5-15-5-core20/7
/dev/loop34 43K 43K 0 100% /snap/kf5-5-105-qt-5-15-9-core22/5
/dev/loop36 32K 32K 0 100% /snap/libreoffice/272
/dev/loop37 43K 43K 0 100% /snap/kf5-5-104-qt-5-15-8-core22/7
/dev/loop38 13K 13K 0 100% /snap/core/14946
/dev/loop40 28K 28K 0 100% /snap/wine-platform-runtime/343
/dev/loop39 18K 18K 0 100% /snap/gnome-3-38-2004/140
/dev/loop41 27K 27K 0 100% /snap/gnome-3-26-1604/111
/dev/loop42 32K 32K 0 100% /snap/libreoffice/275
/dev/loop43 16K 16K 0 100% /snap/dbtarzan/18
/dev/loop44 42K 42K 0 100% /snap/kde-frameworks-5-qt-5-15-3-core20/8
/dev/loop45 14K 14K 0 100% /snap/core22/607
/dev/loop46 12K 12K 0 100% /snap/core20/1828
/dev/loop47 75K 75K 0 100% /snap/gtk-common-themes/1535
/dev/loop48 20K 20K 0 100% /snap/gnome-42-2204/87
/dev/mmcblk0p1 0 0 0 - /boot/efi
tmpfs 477K 52 477K 1% /run/user/1000
talyadavies@talyadavies-E201NAS:~$ ^C
One of the quickest wins you can get is by removing large, old snaps which you don't need. By default snap keeps the current and an old version of applications in case something goes wrong, so you can roll back.
I note you have multiple revisions of LibreOffice installed, which is quite large (1.1GB).
Remove the old one with:
sudo snap remove libreoffice --revision=272
Then I'd sudo apt install ncdu and run ncdu ~ which will show you what's eating space in your home directory. You may have large downloads or other files you could clean up.
popey
  • 24,549
I ran ncdu as advised below and found that
.thunderbird is taking up 24.7 GiB - almost half of my disk space.
I will need to delete old emails (it won't let me compact folders because there is not enough disk space to do that) or else forego my locally saved emails and just find out how to delete .thunderbird - which I think is the folder Thunderbird Mail uses to save emails - as I don't need a local copy of old emails.
