-3
I'm trying to install CUDA 11 on top of ubuntu 18.04 for arm64 on the Jetson nano. This is what happened :
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/sbsa/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget http://developer.download.nvidia.com/compute/cuda/11.0.2/local_installers/cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo dpkg -i cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo apt-key add /var/cuda-repo-ubuntu1804-11-0-local/7fa2af80.pub
sudo apt-get update
Downloading di:1 file:/var/cuda-repo-l4t-10-2-local InRelease
Ignored:1 file:/var/cuda-repo-l4t-10-2-local InRelease
Downloading di:2 file:/var/cuda-repo-ubuntu1804-11-0-local InRelease
Ignored:2 file:/var/cuda-repo-ubuntu1804-11-0-local InRelease
Downloading di:3 file:/var/visionworks-repo InRelease
Ignored:3 file:/var/visionworks-repo InRelease
Downloading di:4 file:/var/visionworks-sfm-repo InRelease
Ignored:4 file:/var/visionworks-sfm-repo InRelease
Downloading di:5 file:/var/visionworks-tracking-repo InRelease
Ignored:5 file:/var/visionworks-tracking-repo InRelease
Downloading di:6 file:/var/cuda-repo-l4t-10-2-local Release [564 B]
Downloading di:7 file:/var/cuda-repo-ubuntu1804-11-0-local Release [564 B]
Downloading di:8 file:/var/visionworks-repo Release [2,001 B]
Downloading di:9 file:/var/visionworks-sfm-repo Release [2,005 B]
Downloading di:10 file:/var/visionworks-tracking-repo Release [2,010 B]
Downloading di:11 file:/var/cuda-repo-ubuntu1804-11-0-local Release.gpg [836 B]
Found:12 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Downloading of:13 http://ppa.launchpad.net/pipewire-debian/pipewire-upstream/ubuntu bionic InRelease [21.3 kB]
Ignored:16 https://esm.ubuntu.com/apps/ubuntu bionic-apps-security InRelease
Downloading of:18 https://repo.download.nvidia.com/jetson/common r32.7 InRelease [2,555 B]
Downloading of:14 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Downloading of:19 https://repo.download.nvidia.com/jetson/t210 r32.7 InRelease [2,550 B]
Ignored:20 https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates InRelease
Downloading of:15 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [83.3 kB]
Ignored:22 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security InRelease
Downloading of:17 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Ignored:23 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates InRelease
Error:24 https://esm.ubuntu.com/apps/ubuntu bionic-apps-security Release Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate. Could not handshake: Error in the certificate verification. [IP: 185.125.190.24 443]
Error:26 https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates Release
Error:27 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security Release
Error:28 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates Release
Downloading di:31 file:/var/cuda-repo-ubuntu1804-11-0-local Packages [21.9 kB] Reading packages list... Done
E: The repository "https://esm.ubuntu.com/apps/ubuntu bionic-apps-security Release" don't have a file Release anymore.
N: Updating from such a repository cannot be done securely and is therefore disabled by default.
E: The repository "https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates Release" don't have a file Release anymore.
E: The repository "https://esm.ubuntu.com/infra/ubuntu bionic-infra-security Release" don't have a file Release anymore.
E: The repository "https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates Release" don't have a file Release anymore.
E: File Release for http://ppa.launchpad.net/pipewire-debian/pipewire-upstream/ubuntu/dists/bionic/InRelease is not valid yet (non valido per 35g 13h 6min 9s). Updates for this repository will not be applied.
E: File Release for https://repo.download.nvidia.com/jetson/common/dists/r32.7/InRelease is not valid yet (non valido per 60g 12h 44min 23s). Updates for Updates for this repository will not be applied.
E: File Release for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease is not valid yet (non valido per 62g 20h 22min 15s). Updates for Updates for this repository will not be applied.
E: File Release for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease is not valid yet (non valido per 62g 19h 46min 21s). Updates for Updates for this repository will not be applied.
E: File Release for http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease is not valid yet (non valido per 62g 19h 42min 54s). Updates for Updates for this repository will not be applied.
sudo apt-get -y install cuda
Following additional packages will be installed :
cuda-11-0 cuda-command-line-tools-11-0 cuda-compiler-11-0 cuda-cudart-11-0 cuda-cudart-dev-11-0 cuda-cuobjdump-11-0 cuda-cupti-11-0 cuda-cupti-dev-11-0 cuda-documentation-11-0 cuda-driver-dev-11-0 cuda-drivers cuda-drivers-450 cuda-gdb-11-0 cuda-libraries-11-0 cuda-libraries-dev-11-0 cuda-nsight-compute-11-0 cuda-nsight-systems-11-0 cuda-nvcc-11-0 cuda-nvdisasm-11-0 cuda-nvml-dev-11-0 cuda-nvprof-11-0 cuda-nvprune-11-0 cuda-nvrtc-11-0 cuda-nvrtc-dev-11-0 cuda-nvtx-11-0 cuda-runtime-11-0 cuda-samples-11-0 cuda-sanitizer-11-0 cuda-toolkit-11-0 cuda-tools-11-0 cuda-visual-tools-11-0 dkms libcublas-11-0 libcublas-dev-11-0 libcufft-11-0 libcufft-dev-11-0 libcurand-11-0 libcurand-dev-11-0 libcusolver-11-0 libcusolver-dev-11-0 libcusparse-11-0 libcusparse-dev-11-0 libnpp-11-0 libnpp-dev-11-0 libnvidia-cfg1-450 libnvidia-common-450 libnvidia-compute-450 libnvidia-decode-450 libnvidia-encode-450 libnvidia-extra-450 libnvidia-fbc1-450 libnvidia-gl-450 libnvidia-ifr1-450 libnvjpeg-11-0 libnvjpeg-dev-11-0 libxnvctrl0 linux-headers-4.15.0-208 linux-headers-4.15.0-208-generic linux-headers-generic nsight-compute-2020.1.1 nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b nvidia-compute-utils-450 nvidia-dkms-450 nvidia-driver-450 nvidia-kernel-common-450 nvidia-kernel-source-450 nvidia-modprobe nvidia-prime nvidia-settings nvidia-utils-450 screen-resolution-extra xserver-xorg-video-nvidia-450 I seguenti pacchetti NUOVI saranno installati: cuda cuda-11-0 cuda-command-line-tools-11-0 cuda-compiler-11-0 cuda-cudart-11-0 cuda-cudart-dev-11-0 cuda-cuobjdump-11-0 cuda-cupti-11-0 cuda-cupti-dev-11-0 cuda-documentation-11-0 cuda-driver-dev-11-0 cuda-drivers cuda-drivers-450 cuda-gdb-11-0 cuda-libraries-11-0 cuda-libraries-dev-11-0 cuda-nsight-compute-11-0 cuda-nsight-systems-11-0 cuda-nvcc-11-0 cuda-nvdisasm-11-0 cuda-nvml-dev-11-0 cuda-nvprof-11-0 cuda-nvprune-11-0 cuda-nvrtc-11-0 cuda-nvrtc-dev-11-0 cuda-nvtx-11-0 cuda-runtime-11-0 cuda-samples-11-0 cuda-sanitizer-11-0 cuda-toolkit-11-0 cuda-tools-11-0 cuda-visual-tools-11-0 dkms libcublas-11-0 libcublas-dev-11-0 libcufft-11-0 libcufft-dev-11-0 libcurand-11-0 libcurand-dev-11-0 libcusolver-11-0 libcusolver-dev-11-0 libcusparse-11-0 libcusparse-dev-11-0 libnpp-11-0 libnpp-dev-11-0 libnvidia-cfg1-450 libnvidia-common-450 libnvidia-compute-450 libnvidia-decode-450 libnvidia-encode-450 libnvidia-extra-450 libnvidia-fbc1-450 libnvidia-gl-450 libnvidia-ifr1-450 libnvjpeg-11-0 libnvjpeg-dev-11-0 libxnvctrl0 linux-headers-4.15.0-208 linux-headers-4.15.0-208-generic linux-headers-generic nsight-compute-2020.1.1 nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b nvidia-compute-utils-450 nvidia-dkms-450 nvidia-driver-450 nvidia-kernel-common-450 nvidia-kernel-source-450 nvidia-modprobe nvidia-prime nvidia-settings nvidia-utils-450 screen-resolution-extra xserver-xorg-video-nvidia-450
Downloading:1 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-cudart-11-0 11.0.194-1 [124 kB]
Downloading:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 dkms all 2.3-3ubuntu9.7 [68.1 kB]
Downloading:3 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvrtc-11-0 11.0.194-1 [5,926 kB]
Downloading:4 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b arm64 2021.5.4.19-e642d4b [67.3 MB]
Downloading:5 http://ports.ubuntu.com/ubuntu-ports bionic/main arm64 screen-resolution-extra all 0.17.3 [11.7 kB]
Downloading:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-4.15.0-208 all 4.15.0-208.220 [11.0 MB]
Downloading:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-4.15.0-208-generic arm64 4.15.0-208.220 [895 kB]
Ignored:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-generic arm64 4.15.0.208.191
Downloading:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 nvidia-prime all 0.8.16~0.18.04.1 [9,224 B]
Error:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-generic arm64 4.15.0.208.191 404 Not Found [IP: 185.125.190.36 80]
Downloading:10 file:/var/cuda-repo-ubuntu1804-11-0-local libcublas-11-0 11.1.0.229-1 [116 MB]
Downloading:11 file:/var/cuda-repo-ubuntu1804-11-0-local libcufft-11-0 10.2.0.218-1 [97.9 MB]
Downloading:12 file:/var/cuda-repo-ubuntu1804-11-0-local libcurand-11-0 10.2.1.218-1 [39.0 MB]
Downloading:13 file:/var/cuda-repo-ubuntu1804-11-0-local libcusolver-11-0 10.5.0.218-1 [284 MB]
Downloading:14 file:/var/cuda-repo-ubuntu1804-11-0-local libcusparse-11-0 11.1.0.218-1 [72.9 MB]
Downloading:15 file:/var/cuda-repo-ubuntu1804-11-0-local libnpp-11-0 11.1.0.218-1 [56.3 MB]
Downloading:16 file:/var/cuda-repo-ubuntu1804-11-0-local libnvjpeg-11-0 11.1.0.218-1 [1,275 kB]
Downloading:17 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-libraries-11-0 11.0.2-1 [2,490 B]
Downloading:18 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-common-450 450.51.05-0ubuntu1 [10.0 kB]
Downloading:19 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-compute-450 450.51.05-0ubuntu1 [9,231 kB]
Downloading:20 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-decode-450 450.51.05-0ubuntu1 [1,077 kB]
Downloading:21 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-encode-450 450.51.05-0ubuntu1 [39.5 kB]
Downloading:22 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-fbc1-450 450.51.05-0ubuntu1 [7,040 B]
Downloading:23 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-gl-450 450.51.05-0ubuntu1 [54.9 MB]
Downloading:24 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-ifr1-450 450.51.05-0ubuntu1 [7,068 B]
Downloading:25 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-compute-utils-450 450.51.05-0ubuntu1 [109 kB]
Downloading:26 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-kernel-source-450 450.51.05-0ubuntu1 [11.6 MB]
Downloading:27 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-kernel-common-450 450.51.05-0ubuntu1 [9,402 B]
Downloading:28 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-dkms-450 450.51.05-0ubuntu1 [26.7 kB]
Downloading:29 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-extra-450 450.51.05-0ubuntu1 [38.0 kB]
Downloading:30 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-driver-450 450.51.05-0ubuntu1 [411 kB]
Downloading:31 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-utils-450 450.51.05-0ubuntu1 [347 kB]
Downloading:32 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-cfg1-450 450.51.05-0ubuntu1 [74.2 kB]
Downloading:33 file:/var/cuda-repo-ubuntu1804-11-0-local xserver-xorg-video-nvidia-450 450.51.05-0ubuntu1 [1,235 kB]
Downloading:34 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-modprobe 450.51.05-0ubuntu1 [17.7 kB]
Downloading:35 file:/var/cuda-repo-ubuntu1804-11-0-local libxnvctrl0 450.51.05-0ubuntu1 [20.5 kB]
Downloading:36 file:/var/cuda-repo-ubuntu1804-11-0-local nvidia-settings 450.51.05-0ubuntu1 [826 kB]
Downloading:37 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-drivers-450 450.51.05-1 [2,628 B]
Downloading:38 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-drivers 450.51.05-1 [2,504 B]
Downloading:39 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-runtime-11-0 11.0.2-1 [2,426 B]
Downloading:40 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-cuobjdump-11-0 11.0.194-1 [91.3 kB]
Downloading:41 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-driver-dev-11-0 11.0.194-1 [26.1 kB]
Downloading:42 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-cudart-dev-11-0 11.0.194-1 [1,609 kB]
Downloading:43 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvcc-11-0 11.0.194-1 [15.7 MB]
Downloading:44 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvprune-11-0 11.0.167-1 [46.5 kB]
Downloading:45 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-compiler-11-0 11.0.2-1 [2,422 B]
Downloading:46 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvrtc-dev-11-0 11.0.194-1 [22.0 kB]
Downloading:47 file:/var/cuda-repo-ubuntu1804-11-0-local libcublas-dev-11-0 11.1.0.229-1 [118 MB]
Downloading:48 file:/var/cuda-repo-ubuntu1804-11-0-local libcufft-dev-11-0 10.2.0.218-1 [176 MB]
Downloading:49 file:/var/cuda-repo-ubuntu1804-11-0-local libcurand-dev-11-0 10.2.1.218-1 [39.2 MB]
Downloading:50 file:/var/cuda-repo-ubuntu1804-11-0-local libcusolver-dev-11-0 10.5.0.218-1 [17.6 MB]
Downloading:51 file:/var/cuda-repo-ubuntu1804-11-0-local libcusparse-dev-11-0 11.1.0.218-1 [72.8 MB]
Downloading:52 file:/var/cuda-repo-ubuntu1804-11-0-local libnpp-dev-11-0 11.1.0.218-1 [57.3 MB]
Downloading:53 file:/var/cuda-repo-ubuntu1804-11-0-local libnvjpeg-dev-11-0 11.1.0.218-1 [1,243 kB]
Downloading:54 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-libraries-dev-11-0 11.0.2-1 [2,514 B]
Downloading:55 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-cupti-11-0 11.0.194-1 [3,551 kB]
Downloading:56 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-cupti-dev-11-0 11.0.194-1 [124 kB]
Downloading:57 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvdisasm-11-0 11.0.194-1 [27.2 MB]
Downloading:58 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-gdb-11-0 11.0.194-1 [2,925 kB]
Downloading:59 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvprof-11-0 11.0.194-1 [18.0 kB]
Downloading:60 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvtx-11-0 11.0.167-1 [51.8 kB]
Downloading:61 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-sanitizer-11-0 11.0.194-1 [5,553 kB]
Downloading:62 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-command-line-tools-11-0 11.0.2-1 [2,472 B]
Downloading:63 file:/var/cuda-repo-ubuntu1804-11-0-local nsight-compute-2020.1.1 2020.1.1.8-1 [75.0 MB]
Downloading:64 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nsight-compute-11-0 11.0.2-1 [3,574 B]
Downloading:65 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nsight-systems-11-0 11.0.2-1 [3,284 B]
Downloading:66 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-nvml-dev-11-0 11.0.167-1 [71.9 kB]
Downloading:67 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-visual-tools-11-0 11.0.2-1 [2,934 B]
Downloading:68 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-tools-11-0 11.0.2-1 [2,382 B]
Downloading:69 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-samples-11-0 11.0.194-1 [42.3 MB]
Downloading:70 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-documentation-11-0 11.0.207-1 [59.6 MB]
Downloading:71 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-toolkit-11-0 11.0.2-1 [2,726 B]
Downloading:72 file:/var/cuda-repo-ubuntu1804-11-0-local cuda-11-0 11.0.2-1 [2,440 B]
Downloading:73 file:/var/cuda-repo-ubuntu1804-11-0-local cuda 11.0.2-1 [2,392 B]
This seems to be the real error :
E: Can't get package from http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-meta/linux-headers-generic_4.15.0.208.191_arm64.deb 404 Not Found [IP: 185.125.190.36 80]
E: Can't get some packages. You need to run "apt-get update" or try option "--fix-missing".
Someone knows where I can get that file ? Do you have some suggestion to give to me ? (I tried the option "apt-get update --fix-missing" ; it didn't work,the error is the same. It needs to find and install the package "linux-headers-generic_4.15.0.208.191_arm64.deb",but it cannot be found and the upgrading process stops.
Marietto
  • 635
  • 13
  • 40
4.15.0.208.191 is an obsolete kernel (meta) package version, no longer available in the repo. Your steps seem to want to pull in header packages probably for all installed kernels. Update your system, specifically the kernel, and remove unused/obsolete kernel packages.
I was able to install CUDA 11 on an updated 18.04 system using your steps.
juergh
  • 26
