I have installed Ubuntu Core (ubuntu-core-22-amd64.img.xz) on a NUC. Using these instructions: https://ubuntu.com/core/docs/install-nuc.
When I get the screen, which is similar to when I have successfully booted a server. I am unable to ssh in.
I have created my Ubuntu One account. And loaded a public key (which does not have a passphrase). I went as far as to spin up two VirtualBox instances using the tutorial above. And was able to SSH to both VMs with the public key on my Ubuntu account.
Here is what I get when attempting to ssh to the physical NUC, not the VM. As with the VMs I can successfully ssh in.
ssh -vvvvvvvv -i ~/.ssh/id_rsa_ubuntu_core xxxxxx@xxx.xx.xx.x
OpenSSH_8.6p1, LibreSSL 3.3.6
debug1: Reading configuration data /Users/x/.ssh/config
debug1: /Users/x/.ssh/config line 5: Applying options for *
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 21: include /etc/ssh/ssh_config.d/* matched no files
debug1: /etc/ssh/ssh_config line 54: Applying options for *
debug2: resolve_canonicalize: hostname xxx.xx.xx.x is address
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts' -> '/Users/x/.ssh/known_hosts'
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts2' -> '/Users/x/.ssh/known_hosts2'
debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling
debug3: ssh_connect_direct: entering
debug1: Connecting to xxx.xx.xx.x [xxx.xx.xx.x] port 22.
debug3: set_sock_tos: set socket 3 IP_TOS 0x48
debug1: connect to address xxx.xx.xx.x port 22: Operation timed out
ssh: connect to host xxx.xx.xx.x port 22: Operation timed out
