Hi i have this issue with 3 domains on my server with ububtu 22.04 and apache
I have 3 domains in a shared hosting, each one with their own web page domain-a.com
domain-b.com
domain-c.com
I also have 3 domains in no-ip, which I have redirected to a server in my house that has a dynamic ip (for this reason, the use of no-ip)
in my house I have configured
domain-a.no-ip.com
domain-b.no-ip.com
domain-c.no-ip.com
In each one I have created its own website in apache
/var/www/domain-a (this web use port 8180)
/var/www/domain-b (this web use port 8185)
/var/www/domain-c (this web use port 8190)
I have also created 3 configuration files, one for each domain on /etc/apache2/sites-available
Also i enable the 3 conf files
sudo a2dissite 000-default
sudo a2ensite domain-a.conf
sudo a2ensite domain-b.conf
sudo a2ensite domain-c.conf
sudo service apache2 restart
<VirtualHost *:80>
   ServerName domain-a.no-ip.com
   Redirect / https://domain-a.no-ip.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =domain-a.no-ip.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<IfModule mod_ssl.c>
         <VirtualHost _default_:443>
             ServerAdmin domain@domain.com
             DocumentRoot /var/www/domain-a/
             ProxyPass / http://localhost:8180/
             ProxyPassReverse / http://localhost:8180/
             SSLEngine on
             SSLCertificateFile /etc/letsencrypt/live/domain-a.no-ip.com/fullchain.pem
             SSLCertificateKeyFile /etc/letsencrypt/live/domain-a.no-ip.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf </VirtualHost> </IfModule>
<VirtualHost *:80> ServerName domain-b.no-ip.com Redirect / https://domain-b.no-ip.com/ RewriteEngine on RewriteCond %{SERVER_NAME} =domain-b.no-ip.com RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent] </VirtualHost> <IfModule mod_ssl.c> <VirtualHost default:443>
             DocumentRoot /var/www/domain-b/
             ProxyPass / http://localhost:8185/
             ProxyPassReverse / http://localhost:8185/
             SSLEngine on
             SSLCertificateFile /etc/letsencrypt/live/domain-b.no-ip.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/domain-b.no-ip.com/privkey.pem </VirtualHost> </IfModule>
<VirtualHost *:80> ServerName domain-c.no-ip.com Redirect / https://domain-c.no-ip.com/ RewriteEngine on RewriteCond %{SERVER_NAME} =domain-c.no-ip.com RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent] </VirtualHost> <IfModule mod_ssl.c> <VirtualHost default:443>
             DocumentRoot /var/www/domain-c
             ProxyPass / http://localhost:8190/
             ProxyPassReverse / http://localhost:8190/
             SSLEngine on
             SSLCertificateFile /etc/letsencrypt/live/domain-c.no-ip.com/fullchain.pem
             SSLCertificateKeyFile /etc/letsencrypt/live/domain-c.no-ip.com/privkey.pem
Then in the cloudflare of domain-a i created a CNAME www2 and the target domain-a.no-ip.com
Then in the cloudflare of domain-b i created a CNAME www2 and the target domain-b.no-ip.com
Then in the cloudflare of domain-c i created a CNAME www2 and the target domain-c.no-ip.com
Now if I enter on any web-browser and put www2.domain-a.com or www2.domain-b.com or www2.domain-c.com always redirects me to domain-b on my server at home
But if I enter through the direct addresses domain-a.no-ip.com or domain-b.no-ip.com or domain-c.no-ip.com it sends me to each web page of the server in my house
What surprises me is that if I enter through the no-ip addresses, it redirects me to each of the 3 pages on my server, but if I enter through the 3 cnames, it always redirects me to the domain-b
Thank you
Leandro
A simple way to resolve this is with ServerAlias in the Apache configuration. Try something like this:
<VirtualHost *:80>
    ServerAlias domain-c.com
    RewriteEngine on
</VirtualHost>
<IfModule mod_ssl.c> <VirtualHost default:443> ServerName domain-c.no-ip.com ServerAlias domain-c.com ServerAdmin domain@domain.com
    SSLEngine on
With ServerAlias, you can also configure multiple domains to point to the same source directory. For example:
ServerAlias domain-c.com *.domain-c.com domain-c.net domain-c.org
Note: Wildcards are supported in the ServerAlias values.
One item to note is that the Let's Encrypt SSL certificate may not work with your CloudFlare domain unless the certificate is valid for multiple domains, or if you are using CloudFlare's SSL externally and forwarding traffic to your home server over HTTP.
matigo
  • 24,752
  • 50
  • 79
