my question is about using the SPI interface to do some things with CAN. On my Raspberry with the Raspberry OS everything worked fine.
Since I want to use the CAN data with ROS, I decided to install Ubuntu Server 20.04 on it. In doing so, I ran into a problem (Cannot find device "can").
These are my configurations:
$ nano /boot/config.txt
dtoverlay=mcp2515-can0,oscillator=16000000,interrupt=25 dtoverlay=mcp2515-can1,oscillator=16000000,interrupt=25 dtoverlay=spi-bcm2835 dtparam=spi=on
$ ./can_setup.sh
#!/bin/bash
ip link set can0 up type can bitrate 1000000 ip link set can1 up type can bitrate 1000000
$ ls /dev/
shows me that spidev0.0 and spidev0.1 are present
I have analyzed MISO MOSI and SCK with a logic analyzer and seen nothing.
Can someone help me?
assuming, that you use Ubuntu as OS for running ROS, you should make your entries for dtoverlay inside the /etc/firmware/config.txt.
My can bus device with MCP2515 works fine with Ubuntu 22.04.
Then try
ls /sys/bus/spi/devices/spi0.0/net
It should show something like
can0
Hope this helps ...
jon_doe
