The solution on post:
How can I fix apt error "W: Target Packages ... is configured multiple times"?
dont seem to answer my question since my duplicates are not both inside "/etc/apt/sources.list"
The python script only applies to "/etc/apt/sources.list" and not "/etc/apt/sources.list.d"
System settings >> Software and Updates >> Other Software:
No duplicate there either
First of all, sorry my system is installed in french so it might be harder to follow.
(I figure if someone has the skill to help me on this one, he/she will understand the issue anyway trough the outputs I get from terminal. I can translate if needed)
Ok so I have most likely installed wine twice, once official way and once more following a tutorial to play starcraft :P (It was fun while it lasted)
Used one or both of those sites:
http://notepad2.blogspot.com/2021/04/install-starcraft-broodwar-on-ubuntu.html
and
https://github.com/edemirkan/wine-starcraft-installer
Lately when I use "sudo apt update", it works fine but I get this:
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Tous les paquets sont à jour.
W: La cible Packages (main/binary-amd64/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Packages (main/binary-i386/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Packages (main/binary-all/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Translations (main/i18n/Translation-fr_CA) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Translations (main/i18n/Translation-fr) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Translations (main/i18n/Translation-en) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible DEP-11 (main/dep11/Components-amd64.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible DEP-11 (main/dep11/Components-all.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible DEP-11-icons-small (main/dep11/icons-48x48.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible DEP-11-icons (main/dep11/icons-64x64.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible CNF (main/cnf/Commands-amd64) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible CNF (main/cnf/Commands-all) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
W: La cible Packages (main/binary-amd64/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list:55 et /etc/apt/sources.list.d/winehq-focal.sources:1
I tried moving "winehq-focal.sources" out of "/etc/apt/sources.list.d" folder. But then instead of those errors, I get this instead:
W: Une erreur s'est produite lors du contrôle de la signature. Le dépôt n'est pas mis à jour et les fichiers d'index précédents seront utilisés. Erreur de GPG : https://dl.winehq.org/wine-builds/ubuntu focal InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 76F1A20FF987672F
W: Impossible de récupérer https://dl.winehq.org/wine-builds/ubuntu/dists/focal/InRelease Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 76F1A20FF987672F
W: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
I found out I could get rid of this by removing the key but I dont seem to have it:
apt-key list
/etc/apt/trusted.gpg
pub rsa2048 2016-06-22 [SC] D404 0146 BE39 7250 9FD5 7FC7 1F30 45A5 DF75 87C3 uid [ inconnue] Skype Linux Client Repository se-um@microsoft.com sub rsa2048 2016-06-22 [E]
/etc/apt/trusted.gpg.d/ubuntu-keyring-2012-archive.gpg
pub rsa4096 2012-05-11 [SC] 790B C727 7767 219C 42C8 6F93 3B4F E6AC C0B2 1F32 uid [ inconnue] Ubuntu Archive Automatic Signing Key (2012) ftpmaster@ubuntu.com
/etc/apt/trusted.gpg.d/ubuntu-keyring-2012-cdimage.gpg
pub rsa4096 2012-05-11 [SC] 8439 38DF 228D 22F7 B374 2BC0 D94A A3F0 EFE2 1092 uid [ inconnue] Ubuntu CD Image Automatic Signing Key (2012) cdimage@ubuntu.com
/etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg
pub rsa4096 2018-09-17 [SC] F6EC B376 2474 EDA9 D21B 7022 8719 20D1 991B C93C uid [ inconnue] Ubuntu Archive Automatic Signing Key (2018) ftpmaster@ubuntu.com
/etc/apt/trusted.gpg.d/ztefn_ubuntu_haguichi-stable.gpg
pub rsa4096 2015-07-09 [SC] D071 2F35 B203 37C0 0C94 E829 EB75 B0EB E2C8 21AC uid [ inconnue] Launchpad PPA for Stephen Brandt
I might add "cat -n sources.list"
(Skipping 1 trough 54)
55 deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
56 # deb-src https://dl.winehq.org/wine-builds/ubuntu/ focal main
And "cat -n winehq-focal.sources"
1 Types: deb
2 URIs: https://dl.winehq.org/wine-builds/ubuntu
3 Suites: focal
4 Components: main
5 Architectures: amd64 i386
6 Signed-By: /usr/share/keyrings/winehq-archive.key
Any Idea how to fix this mess? Thank you in advance, it is much appreciated!!!!
