So i have Ubuntu 22.04.2 LTS installed on my laptop. It takes more than 2 mins to bootup which seems too much for me. When i had installed Ubuntu on my machine a couple of months ago it didnt take this much time. Here are the logs generated by "systemd-analyze" and "system-analyze blame" respectively
isaac@Isaac-Lenovo-IdeaPad-S145-15AST:~$ systemd-analyze
Startup finished in 4.979s (firmware) + 8.472s (loader) + 4.847s (kernel) + 1min 59.732s (userspace) = 2min 18.032s graphical.target reached after 1min 59.606s in userspace
isaac@Isaac-Lenovo-IdeaPad-S145-15AST:~$ systemd-analyze blame
1min 22.046s fstrim.service
 57.290s plymouth-quit-wait.service
 37.756s systemd-journal-flush.service
 33.487s dev-mapper-vgubuntu\x2droot.device
 31.672s apt-daily.service
 26.775s snapd.service
 23.608s logrotate.service
 21.060s networkd-dispatcher.service
 20.841s snap-bare-5.mount
 19.967s snap-core18-2714.mount
 19.579s NetworkManager-wait-online.service
 19.316s snap-core18-2721.mount
 18.666s udisks2.service
 18.013s snap-core20-1778.mount
 16.502s snap-core20-1852.mount
 13.452s snap-core22-583.mount
 13.435s ModemManager.service
 13.344s accounts-daemon.service
 13.160s dev-loop28.device
 13.022s dev-loop19.device
 12.719s dev-loop18.device
 12.715s dev-loop23.device
 12.713s dev-loop26.device
Also here are my specs
CPU : AMD® A6-9225 radeon r4, 5 compute cores 2c+3g × 2
GPU : No external. iGPU (STONEY (stoney, LLVM 15.0.6, DRM 3.42, 5.15.0-69-generic))
HDD : 1TB
RAM : 4GB
OS  : Ubuntu 22.04.2 LTS (64 bit)
SSD : No SSD
So is there any solution to this problem? Also is there any fault in my system or do i just need to upgrade my hardware...?
[Solved] Thanks to @Archisman Panigrahi i was able to remove all the snap apps and the snap itself which decreased my bootup time at a noticable degree. Here are the logs after removing snap
Startup finished in 5.810s (firmware) + 5.990s (loader) + 5.145s (kernel) + 1min 35.600s (userspace) = 1min 52.547s
graphical.target reached after 1min 35.524s in userspace
49.362s plymouth-quit-wait.service
31.030s systemd-journal-flush.service
23.653s dev-mapper-vgubuntu\x2droot.device
17.721s systemd-udevd.service
16.684s networkd-dispatcher.service
15.613s NetworkManager-wait-online.service
13.481s udisks2.service
10.818s accounts-daemon.service
 8.654s ModemManager.service
 7.616s power-profiles-daemon.service
 7.567s polkit.service
 7.249s cups.service
 7.019s gdm.service
 6.680s NetworkManager.service
 6.674s bluetooth.service
 6.170s switcheroo-control.service
 6.134s thermald.service
 6.133s systemd-logind.service
 5.845s wpa_supplicant.service
 4.695s systemd-resolved.service
 3.518s rsyslog.service
 3.078s apparmor.service
 2.785s e2scrub_reap.service
The logs say that snap events take a lot of time in boot. I too have personally experienced this issue in older computers with HDDs, where removing snap improved the boot speed considerably. Replace all snap apps with apt apps, and uninstall snapd.
Here is how to replace Firefox snap, if you use Firefox, and here is how to remove snapd altogether.
You can also disable apt-daily.service (then you will have to regularly check for updates manually, and keep your system updated).
sudo systemctl disable apt-daily.service
Also, systemd-journal-flush.service is taking a lot of time. So, clearing the systemd logs can speed up the boot process further.
sudo journalctl --flush --rotate
sudo journalctl --vacuum-size=20M
You can also safely disable NetworkManager-wait-online.service
sudo systemctl disable NetworkManager-wait-online.service
