Since upgrading to 23.04 I've noticed that my laptop no longer enters deep sleep (suspend to RAM / S0i3). One of the reasons I switched from Tumbleweed back to Ubuntu was that I had issues getting S0ix sleep states to work, but when I installed Ubuntu 22.10 it worked out of the box.
Now when I put my laptop to sleep the battery will just barely last overnight, whereas prior to the upgrade it would last at least several days. Can anyone suggest where I should start trying to diagnose what's gone wrong?
RAS
  • 101
I have the same issue when set the laptop to sleep using Kubuntu 23.04 and the sleep option in the menu. I did not find a solution to this yet, but a workaround. The laptop goes to sleep when with pm-suspend. This however does not lock the session. So I use this command:
sudo echo; qdbus org.freedesktop.ScreenSaver /ScreenSaver Lock; sudo pm-suspend
Not user friendly, but works.
Den
  • 151
