This seems to be the same as another question asked yesterday.
I’m having a problem with getting an Intel gigabit interface to operate at full speed.
System is a Supermicro X7DA8 dual Xeon. It has two Intel “Pro/1000 EB” interfaces on the motherboard.
The system dual-boots Ubuntu Studio 20.04.4 and MS Windows 7 Pro x64.
The system is used to back up a Supermicro server with 8 4TB SAS disks. That replaced a much older quad Opteron server where the speed was not a problem, but the new server can saturate a GigE wire most of the time and has a much larger partition, so GigE speeds are necessary.
The interface is recognized as a 1 Gb/s interface by Windows 7; I previously ran FreeBSD on it (my server back end has been FreeBSD since the early 1990’s) and that always connected at 1 Gb/s.
The other question had a request to run ethtool:
ethtool enp6s0f1
Settings for enp6s0f1:
    Supported ports: [ TP ]
    Supported link modes:   10baseT/Half 10baseT/Full
                            100baseT/Half 100baseT/Full
                            1000baseT/Full
    Supported pause frame use: No
    Supports auto-negotiation: Yes
    Supported FEC modes: Not reported
    Advertised link modes:  10baseT/Half 10baseT/Full
                            1000baseT/Full
    Advertised pause frame use: No
    Advertised auto-negotiation: Yes
    Advertised FEC modes: Not reported
    Speed: 100Mb/s
    Duplex: Full
    Port: Twisted Pair
    PHYAD: 1
    Transceiver: internal
    Auto-negotiation: on
    MDI-X: on (auto)
Cannot get wake-on-lan settings: Operation not permitted
    Current message level: 0x00000007 (7)
                   drv probe link
    Link detected: yes
I ran the usual lshw and dmesg and discovered in the dmesg that the following:
[52.221560] e1000e 0000:06:00.1 enp6s0f1: Link Speed was downgraded by SmartSpeed.
The driver code seems to choose “Interrupt Throttling Rate (ints/sec) set to dynamic conservative” if the rate will be 100 Mb/s, but I haven’t looked any further (yet).
which is a signal of a bad cable.
The system was connected with a new cable labeled “CAT 6” but I bought a new “CAT 6” cable and when I installed the cable link speed was 1 GB/ps. After a reboot it was 100 Mb/s, and disconnecting and reconnecting didn’t change that.
I tried booting the current Xubuntu version 22.04.2 and it also linked at 100 Mb/s.
I have seen a recent note that there was a kernel bug affecting the Intel chip but I haven’t seen the real announcement so far.
I’ve ordered a non-Intel GigE network card which may provide a workaround.
dmesg output filtered for e1000 is:
[    1.274549] e1000e: Intel(R) PRO/1000 Network Driver
[    1.274593] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.280921] e1000e 0000:06:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    1.341558] e1000e 0000:06:00.0 eth0: (PCI Express:2.5GT/s:Width x4) 00:30:48:7e:cb:cc
[    1.341577] e1000e 0000:06:00.0 eth0: Intel(R) PRO/1000 Network Connection
[    1.341658] e1000e 0000:06:00.0 eth0: MAC: 5, PHY: 5, PBA No: 2050FF-0FF
[    1.341918] e1000e 0000:06:00.1: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    1.382426] e1000e 0000:06:00.1 eth1: (PCI Express:2.5GT/s:Width x4) 00:30:48:7e:cb:cd
[    1.382431] e1000e 0000:06:00.1 eth1: Intel(R) PRO/1000 Network Connection
[    1.382511] e1000e 0000:06:00.1 eth1: MAC: 5, PHY: 5, PBA No: 2050FF-0FF
[    1.384825] e1000e 0000:06:00.1 enp6s0f1: renamed from eth1
[    1.399218] e1000e 0000:06:00.0 enp6s0f0: renamed from eth0
[   52.221436] e1000e 0000:06:00.1 enp6s0f1: NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[   52.221560] e1000e 0000:06:00.1 enp6s0f1: Link Speed was downgraded by SmartSpeed
[   52.221563] e1000e 0000:06:00.1 enp6s0f1: 10/100 speed: disabling TSO
sudo lshw -C net yields
 *-network:0
       description: Ethernet interface
       product: 80003ES2LAN Gigabit Ethernet Controller (Copper)
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: enp6s0f0
       version: 01
       serial: 00:30:48:7e:cb:cc
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.15.0-70-lowlatency firmware=2.1-12 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:24 memory:d2220000-d223ffff memory:d2200000-d221ffff ioport:4000(size=32) memory:d2280000-d228ffff
  *-network:1
       physical id: 0.1
       bus info: pci@0000:06:00.1
       logical name: enp6s0f1
       version: 01
       serial: 00:30:48:7e:cb:cd
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.15.0-70-lowlatency duplex=full firmware=2.1-12 ip=192.168.0.25 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:26 memory:d2260000-d227ffff memory:d2240000-d225ffff ioport:4020(size=32) memory:d2290000-d229ffff
Serg
  • 808
I think the issue may be that the specific version of the Intel GigE chip is not recognized by the current driver. I had a similar problem with the Broadcomm driver on a quad Opteron server system. Rather than really solve the problem which would require messing with the driver code I am using "ethtool" to turn on GigE networking, using "ethtool -s enp6s0f0 autoneg on speed 1000 duplex full" where "enp6s0f0" is what Xubuntu 22.04 renames the Ethernet port. "netstat -i" shows 4 million frames in, 2 million out, zero errors.
