I am using the HPLIP installed from repository, since the one from HPLIP download usually does not install, due to dependencies issues.
When I open the HPLIP Toolbox I get crash with main cause at /usr/share/hplip/toolbox.py. If I run this Phython I get:
HP Linux Imaging and Printing System (ver. 3.22.10)
HP Device Manager ver. 15.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Traceback (most recent call last):
File "/usr/share/hplip/toolbox.py", line 280, in <module>
toolbox = ui.DevMgr5(version, device_uri, None)
File "/usr/share/hplip/ui5/devmgr5.py", line 238, in init
core = CoreInstall(MODE_CHECK)
File "/usr/share/hplip/installer/core_install.py", line 240, in init
self.passwordObj = password.Password(ui_mode)
File "/usr/share/hplip/base/password.py", line 94, in init
self.__readAuthType() # self.__authType
File "/usr/share/hplip/base/password.py", line 119, in __readAuthType
distro_name = get_distro_std_name(os_name)
NameError: name 'get_distro_std_name' is not defined. Did you mean: 'get_distro_name'?
The solution I implemented was to edit file /usr/share/hplip/base/password.py and replace get_distro_std_name() by the get_distro_name(), used on previous Ubuntu, 22.10.
Line 119:
From
To
distro_name = get_distro_name().lower().replace(" ","")
Line 323
From
To
How can this be reported to team in charge of HPLIP code in Ubuntu?
Regards
