I have two machines
  1. machine A with ip 192.168.0.2
  2. machine B with assigned IP 192.168.0.3
They are both connected to a local network and I would like to set the date and time of machine A to match those of machine B.
For a similar problem I would use the solution provided in this answer.
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
However, this would only work if I had an internet connection.
What is the command to sync the time and date of two Ubuntu operating systems without using the internet?
Candidate 1 Thanks to @Joe for the his input. What about setting up a webserver on machine B, querying it from machine A and get the time and date from the response? It looks quite articulated.. is there an easier solution?
Candidate 2 Thanks to @matigo for this. Setting up an NTP server on the local network. Checking NTP docs to implement this solution
UserK
  • 255
If had an internet connection, you could enter the wget command given inside the date command, and see that it yields a time string like this:
25 Apr 2023 13:20:23Z
It does so by taking the date from a HTTP header, stripping off the word "Date:", and tacking a Z at the end. So you can set the time manually by using this format:
sudo date -s "25 Apr 2023 13:20:23Z"
You may possible need to translate "Apr" to an abbreviated month name in your locale.
Jos
  • 30,529
  • 89
  • 96
Setting up a NTP server (as far as I know current Ubuntu versions use chronyd as NTP server) on one machine and using a NTP client (chronyc, conversely) on the other to sync to the server machine seems to be the best way.
Another option is to use the "good old" Daytime Protocol. You need to install xinetd on the server machine (the one you will be synchronizing to) and enable daytime service in its configuration (here is some info on how to enable it). Daytime service returns current date and time as a string, so you probably have to write some script on the client machine (the one you want to synchronize to the client machine) to retrieve this information and set clock according to it (I don't know of any ready-made client for daytime protocol). But using NTP still seems better...
raj
  • 11,409
I'm assuming 192.168.0.* must remain inaccessible to and from anywhere else, on account of some security concern. To get external time without too much effort, how about:
  1. install an hypervisor on a different machine with internet access. (It would be ideal if this machine had 2 Ethernet connections, 1 of which facing the internet, the other unused or used for local-only networks)
  2. make this machine a time client of some time server (NTP, Windows domain, whatever).
  3. install a guest OS which is a pre-built NTP server appliance
  4. give the guest appliance a bridged address within 192.168.0.*
  5. Sync this guest time to the host time by means of the hypervisor.
  6. Make this guest itself the self-contained root source for NTP time.
  7. Make all machines on 192.168.0.* NTP clients to this guest appliance
Because the hypervisor (and not a network route) internal mechanism is the means to pass a time reference to the NTP guest appliance, 192.168.0.* has no route to the outside, but still has a good time reference. If the hypervisor host has a network cable used only for local networks, even a promiscuous-mode tap on the outside wire would share nothing of 192.168.0.*
devnull
  • 41
All right, thanks for the precious info you guys provided. After a bit of research and testing here is the solution that I am using.
As Canonical stated here
Since Ubuntu 16.04, timedatectl/timesyncd (which are part of systemd) replace most of ntpdate/ntp.
ntpdate is now considered deprecated in favor of timedatectl (or chrony) and is no longer installed by default. timesyncd will generally do the right thing keeping your time in sync, and chrony will help with more complex cases.
So I gave Chrony a shot. I also checked:
  1. this link here
  2. Stack question,
  3. The Red Hat page
  4. This tutorial
So long story short...
Machine A - Configured as NTP server
sudo apt update && sudo apt upgrade
sudo apt install chrony
sudo vim /etc/chrony/chrony.conf
Configure the NTP server make sure to add local stratum 10 and allow 192.168.0.0/24 to force the server to work normally even if it is disconnected from the internet and that clients on this network are allowed to connect to our Chrony NTP server for time syncing.
confdir /etc/chrony/conf.d
pool ntp.ubuntu.com        iburst maxsources 4
pool 0.ubuntu.pool.ntp.org iburst maxsources 1
pool 1.ubuntu.pool.ntp.org iburst maxsources 1
pool 2.ubuntu.pool.ntp.org iburst maxsources 2
sourcedir /run/chrony-dhcp
sourcedir /etc/chrony/sources.d
keyfile /etc/chrony/chrony.keys
driftfile /var/lib/chrony/chrony.drift
ntsdumpdir /var/lib/chrony
logdir /var/log/chrony
maxupdateskew 100.0
rtcsync
makestep 1 3
leapsectz right/UTC
Restart the chrony service, check that is running and enable it to start on boot
sudo systemctl restart chrony
sudo systemctl status chrony
CTRL+C
sudo systemctl enable chrony
Machine B - Configured as Chrony Client
Synch the date and time with a pool of servers and set the 192.168.0.1 or whichever IP you have as the preferred server.
Add your local NTP server to the pool.
pool 192.168.0.1 iburst prefer
log measurements statistics tracking
maxupdateskew 100.0
rtcsync
makestep 1.0 3
Restart, check the service and enable it at startup
CTRL+C
Finally, check if it gets the update from the right source
chronyc tracking
chronyc sources
Conclusion
Rock n' roll and keep pushing!
I will be conducting a brief test and will update this post with any issues I come across.
UserK
  • 255
