So, I upgraded to 23.04 and I have an issue with apt upgrade where it will say that 4 packages will be "not fully installed or removed". It then proceeds to attempt to configure the kernel I'm currently running, which is 6.2.0-20-generic.
It appears that dpkg is failing due to some dependency, but I'm unsure what it is, exactly. Please see the error log below. There is more after what I paste, but the other packages obviously fail due to the failure to configure the first package. I have researched the issue, but I'm not totally sure what to do.
I have tried uninstalling the kernel, but apt fails at this.
root@5DC:/# apt update
Hit:1 http://security.ubuntu.com/ubuntu lunar-security InRelease
Get:2 http://archive.ubuntu.com/ubuntu lunar InRelease [267 kB]
Hit:3 https://packages.matrix.org/debian focal InRelease
Get:5 http://archive.ubuntu.com/ubuntu lunar-updates InRelease [90.7 kB]
Hit:6 http://archive.ubuntu.com/ubuntu lunar-backports InRelease
Hit:4 https://packagecloud.io/crowdsec/crowdsec/ubuntu jammy InRelease
Fetched 357 kB in 1s (377 kB/s)
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
root@5DC:/# apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-image-6.2.0-20-generic (6.2.0-20.20) ...
Setting up linux-headers-6.2.0-20-generic (6.2.0-20.20) ...
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 6.2.0-20-generic
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module: Cleaning build area... make -j4 KERNELRELEASE=6.2.0-20-generic all INCLUDEDIR=/lib/modules/6.2.0-20-gen eric/build/include KVERSION=6.2.0-20-generic DKMS_BUILD=1...(bad exit status: 2) ERROR (dkms apport): binary package for evdi: 1.12.0 not found Error! Bad return status for module build on kernel: 6.2.0-20-generic (x86_64) Consult /var/lib/dkms/evdi/1.12.0/build/make.log for more information. Error! One or more modules failed to install during autoinstall. Refer to previous errors for more information. ...fail! run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11 dpkg: error processing package linux-headers-6.2.0-20-generic (--configure): installed linux-headers-6.2.0-20-generic package post-installation script subpr ocess returned error exit status 1 dpkg: dependency problems prevent configuration of linux-headers-generic: linux-headers-generic depends on linux-headers-6.2.0-20-generic; however: Package linux-headers-6.2.0-20-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of linux-generic: linux-generic depends on linux-headers-generic (= 6.2.0.20.20); however: Package linux-headers-generic is not configured yet.
dpkg: error processing package linux-generic (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup erro r from a previous failure. No apport report written because the error message ind icates its a followup error from a previous failure. Processing triggers for linu x-image-6.2.0-20-generic (6.2.0-20.20) ... /etc/kernel/postinst.d/dkms:
  • dkms: running auto installation service for kernel 6.2.0-20-generic
Sign command: /usr/bin/kmodsign Signing key: /var/lib/shim-signed/mok/MOK.priv Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module: Cleaning build area... make -j4 KERNELRELEASE=6.2.0-20-generic all INCLUDEDIR=/lib/modules/6.2.0-20-gen eric/build/include KVERSION=6.2.0-20-generic DKMS_BUILD=1...(bad exit status: 2) ERROR (dkms apport): binary package for evdi: 1.12.0 not found Error! Bad return status for module build on kernel: 6.2.0-20-generic (x86_64) Consult /var/lib/dkms/evdi/1.12.0/build/make.log for more information. Error! One or more modules failed to install during autoinstall. Refer to previous errors for more information. ...fail! run-parts: /etc/kernel/postinst.d/dkms exited with return code 11 dpkg: error processing package linux-image-6.2.0-20-generic (--configure): installed linux-image-6.2.0-20-generic package post-installation script subproc ess returned error exit status 1 No apport report written because MaxReports is reached already Errors were encoun tered while processing: linux-headers-6.2.0-20-generic linux-headers-generic linux-generic linux-image-6.2.0-20-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
Nmath
  • 12,664
I had the same, and had to completely remove all dkms modules.
$ dkms status
Will show you the modules. Remove them with:
dkms remove --all modulename
Bram
  • 3,699
Solved by removing the DisplayLink evdi with the command sudo displaylink-installer uninstall
