I'm setting up a dockerfile and one of the included packages should be "python3-tk". However, while building the image, the package asks for a location (???), where you need to specify a value from 1 to 8, depending on your continent (why??) and then timezone.
I tried like this:
RUN apt-get update \
    && apt-get install -y \
        python3-tk \
    && apt-get clean \
    && rm -rf /var/lib/apt/lists/*
No luck, it still asks. When I comment out this code in the dockerfile the image builds fine, so it's definitely this package that is asking for input.
What can I do in this case?
EDIT: This is where it gets stuck:
 => => # questions will narrow this down by presenting a list of cities, representing
 => => # the time zones in which they are located.
 => => #   1. Africa      4. Australia  7. Atlantic  10. Pacific  13. Etc
 => => #   2. America     5. Arctic     8. Europe    11. SystemV
 => => #   3. Antarctica  6. Asia       9. Indian    12. US
 => => # Geographic area:
You need to set the timezone in the docker file before "apt". This is a method:
RUN ln -snf /usr/share/zoneinfo/$CONTAINER_TIMEZONE /etc/localtime && echo $CONTAINER_TIMEZONE > /etc/timezone
What also stops questions is (also set in the beginning of a docker file):
ARG DEBIAN_FRONTEND=noninteractive
Rinzwind
  • 309,379
