I'm having trouble trying to start Zabbix Server (6.4) on WSL2. When I try the following command:
service zabbix-server restart:
I received the following message:
* Stopping Zabbix server zabbix_server
No process in pidfile '/var/run/zabbix/zabbix_server.pid' found running; none killed. [ OK ]
* Starting Zabbix server zabbix_server
And Zabbix Server does not start:
service zabbix-server status:
* zabbix_server is not running
Inside the log file (/var/log/zabbix/zabbix_server.log), is found the follow message repeated several times:
13660:20230417:160028.155 [Z3001] connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13)
Followed with the message in the end of the file:
13660:20230417:160028.155 database is down: reconnecting in 10 seconds 13660:20230417:160032.344 Got signal [signal:15(SIGTERM),sender_pid:15318,sender_uid:0,reason:0]. Exiting ...
13660:20230417:160032.344 Zabbix Server stopped. Zabbix 6.4.1 (revision 546e284fd7c).
But I already installed the mysql-server normally, and it is running without any kind of problem.
