When I want to update my vm I got the error:
E: Method https has died unexpectedly!
E: Sub-process https received signal 4.
I searched the net and with this answer when I run sudo GNUTLS_CPUID_OVERRIDE=0x1 apt-get update with non root user the issue is fixed. But when I add the line export GNUTLS_CPUID_OVERRIDE=0x1 to both /root/.bashrc and myuser/.bashrc and execute source .bashrc the problem is not fixed.
When I login as root user (ssh myuser@host then whoami results myuser. then sudo -i and executing whoami results root in my VM.) and run the command without sudo it's ok. But even with the root user and the sudo prefix, the problem exists.
You can use sudo GNUTLS_CPUID_OVERRIDE=0x1 apt-get update every time you want to update packages, but if you're going to make it permanent and system-wide, you must add export GNUTLS_CPUID_OVERRIDE=0x1 to the /etc/environment file.
