I'm trying to disable both hyperthreading and frequency boost to benchmark some code. Because I cant find anything about this on the BIOS, I ran lscpu to get some information about the CPU (AMD Ryzen 7 4700U) and I get this information
CPU(s):                  8
  On-line CPU(s) list:   0-7
Vendor ID:               AuthenticAMD
  Model name:            AMD Ryzen 7 4700U with Radeon Graphics
    CPU family:          23
    Model:               96
    Thread(s) per core:  1
    Core(s) per socket:  8
    Socket(s):           1
    Stepping:            1
    Frequency boost:     enabled
    CPU max MHz:         2000,0000
    CPU min MHz:         1400,0000
Because there is only 1 thread per core, I'm assuming my CPU does not support hyperthreading (I'm not sure about this).
To disable frequency boost, I have tried running this command, which as far as I understand should clock the CPU to the highest frequency
sudo cpupower frequency-set --governor performance
but when I run lscpu I still get
Does anyone know the correct way to disable both hyperthreading and frequency boost (without using the BIOS because I can't find anything about this there)
EDIT The CPU frequency scaling driver is
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu4/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu5/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu6/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu7/cpufreq/scaling_driver:acpi-cpufreq
Doug Smythies
  • 16,146
Z123
