Whenever I try to install any package, I get the following error:
sudo apt-get install apache2:
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
apache2 : Depends: apache2-bin (= 2.4.52-1ubuntu4.4) but it is not going to be installed
Depends: apache2-data (= 2.4.52-1ubuntu4.4) but it is not going to be installed
Depends: apache2-utils (= 2.4.52-1ubuntu4.4)
docker-ce : Depends: docker-ce-cli but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Whenever I try to fix it, the following error occurs:
sudo apt --fix-broken install:
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
wmdocker
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
docker-ce-cli
The following NEW packages will be installed:
docker-ce-cli
0 to upgrade, 1 to newly install, 0 to remove and 33 not to upgrade.
7 not fully installed or removed.
Need to get 0 B/13.2 MB of archives.
After this operation, 36.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 220691 files and directories currently installed.)
Preparing to unpack .../docker-ce-cli_5%3a23.0.3-1~ubuntu.22.04~jammy_amd64.deb ...
Unpacking docker-ce-cli (5:23.0.3-1~ubuntu.22.04~jammy) ...
dpkg: error processing archive /var/cache/apt/archives/docker-ce-cli_5%3a23.0.3-1~ubuntu.22.04~jammy_amd64.deb (--unpack):
trying to overwrite '/usr/bin/docker', which is also in package podman-docker 3.4.4+ds1-1ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
When I try:
sudo apt update:
Hit:1 http://au.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 https://download.docker.com/linux/ubuntu jammy InRelease
Get:3 http://au.archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
Hit:4 https://deb.nodesource.com/node_18.x jammy InRelease
Get:5 http://au.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
Get:6 http://au.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [992 kB]
Get:7 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:8 http://au.archive.ubuntu.com/ubuntu jammy-updates/main i386 Packages [468 kB]
Get:9 http://au.archive.ubuntu.com/ubuntu jammy-updates/main amd64 DEP-11 Metadata [102 kB]
Get:10 http://au.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 DEP-11 Metadata [269 kB]
Get:11 http://au.archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 DEP-11 Metadata [940 B]
Get:12 http://au.archive.ubuntu.com/ubuntu jammy-backports/main amd64 DEP-11 Metadata [7,988 B]
Get:13 http://au.archive.ubuntu.com/ubuntu jammy-backports/universe amd64 DEP-11 Metadata [12.5 kB]
Hit:14 https://ppa.launchpadcontent.net/ethereum/ethereum/ubuntu jammy InRelease
Fetched 2,189 kB in 2s (1,444 kB/s)
33 packages can be upgraded. Run 'apt list --upgradable' to see them.
When I try:
sudo apt upgrade
I get:
docker-ce : Depends: docker-ce-cli but it is not installed
Can someone please help? I am a noob.
