I have an older version of Ubuntu installed on an older Vista era laptop with only 4 GBs of RAM, but with a modern Samsung solid state drive.
I booted the laptop (which had not been used for over a good year) and it booted to my GUI interface and all looked good. With in less then a minute, it said I have updates to do and to click the button to update. I did this any many updates were installed. No error messages. After the updates were installed, it said to reboot to finish the updates. I rebooted, but the laptop only came up to a blinking cursor. This lasted for many hours and nothing has changed, no matter how many hours I let it sit.
I learned of a command of "Ctrl, Alt, F4" and tried that. A screen came up asking for my user ID and password. After I entered that, another screen came up which almost filled the entire screen (in text, not GUI interface). It says I am running Ubuntu 18.04.6 LTS A205 tty4
I see no error messages. I do see a line of text that says:
"27 additional security updates can be applied with ESM apps."
I also see a line that says:
"Your Hardware enablement stack (HWE)is supported until April 2023"
I wish to upgrade my version of Ubuntu. Because this laptop is so old, I decided on Lubuntu 22.04.2 LTS. I built a flash drive for this and tried to install it.
The trouble is, in this laptops current state, when I turn the Toshiba laptop on, all I get is a blinking cursor - - it will not boot to a GUI interface. When I try to boot to the flash drive of Lubuntu 22.04.2 LTS, the Toshiba will boot to it and I see the selection to try or install Lubuntu 22.04.2 LTS. But when I click on it or I click on the graphic selection below it, nothing happens. I get the blinking cursor. I let it sit for several hours and it is still a blinking cursor.
I think if I could somehow repair, fix, or somehow boot to the GUI interface, I can probably get Lubuntu 22.04.2 to install.
Can anyone point me to some commands I can use from the terminal interface (that I only have access to at this time) so I can perhaps fix the Toshiba so it will boot to the GUI interface?
I think (but I am not sure) that if I can get the Toshiba to boot to GUI interface after I turn it on and off, I can probably load Lubuntu 22.04.2.
But I am not very skilled in Linux so I am open to any other suggestions.
Many thanks,
mraroid
