-1
Structure of my PC was that: SSD 0.5T (C) Windows 10 only, HDD 1TB (E, F) E part contained wastes of stale Windows 7, and F I used for user files and so on misc.
I installed Ubuntu 22.04 using this recommendations: https://medium.com/linuxforeveryone/how-to-install-ubuntu-20-04-and-dual-boot-alongside-windows-10-323a85271a73. Literally, I shrank the free part of E and used it for partitions.
After that I lost access to my Windows 10. My PC boots automatically from HDD, GRUB see Ubuntu (and Windows 7 that can't boot it, obviously). If i press f12 on boot menu, only this way let me choose SSD as boot source, but as I select it - it loads all the same GRUB. sudo update grub does not help. Boot-Repair gives me this info: https://paste.ubuntu.com/p/jJwTxtXxJj/.
============================== Boot Info Summary ===============================
=> Windows 7/8/10/11/2012 is installed in the MBR of /dev/sda. => Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of the same hard drive for core.img. core.img is at this location and looks for (,msdos6)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
sda1: __________________________________________________________________________
File system:       vfat
Boot sector type:  Windows 8/10/11/2012: FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/Boot/bootx64.efi /efi/Boot/fbx64.efi
                   /efi/Boot/mmx64.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
                   /efi/ubuntu/grub.cfg /efi/Microsoft/Boot/bootmgfw.efi
                   /efi/Microsoft/Boot/bootmgr.efi
sda2: __________________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
sda3: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 8/10/11/2012: NTFS
Operating System:  Windows 8 or 10
Boot files:        /Windows/System32/winload.exe
sda4: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sdb1: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 7/2008: NTFS
Operating System:
Boot files:        /bootmgr /Boot/BCD
sdb2: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sdb3: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sdb4: __________________________________________________________________________
File system:       Extended Partition
Boot sector type:  -
Boot sector info:
sdb5: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sdb6: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 22.04.2 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
                   /boot/grub/i386-pc/core.img
sdb7: __________________________________________________________________________
File system:       ext2
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
================================ 3 OS detected =================================
OS#1: Windows 7 (boot) on sdb1 OS#2: Ubuntu 22.04.2 LTS on sdb6 OS#3: Windows 8 or 10 on sda3
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: GK106 [GeForce GTX 660] Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller VESA VGA from NVIDIA Corporation Intel Corporation BOOT_IMAGE of the installed session in use: /boot/vmlinuz-5.19.0-38-generic root=UUID=8c1eacdf-ad06-471b-8500-a24e61e80775 ro quiet splash vt.handoff=7 df -Th / : /dev/sdb6 ext4 15G 13G 1.2G 92% /
===================================== UEFI =====================================
BIOS/UEFI firmware: F3(4.6) from American Megatrends Inc. The firmware is EFI-compatible, but this installed-session is in Legacy/BIOS/CSM mode (not in EFI mode).
64349b3622c65f495a99dbf6102496e3 sda1/Boot/bootx64.efi a9c517741ac31962d7feb152948ad1ee sda1/Boot/fbx64.efi a660182adef313615746a665966d2ccc sda1/Boot/mmx64.efi 5ddf997e8b025bfbc2009e85b32f60dc sda1/ubuntu/grubx64.efi a660182adef313615746a665966d2ccc sda1/ubuntu/mmx64.efi 64349b3622c65f495a99dbf6102496e3 sda1/ubuntu/shimx64.efi 20ac8dde00311476f3755604eb0e545a sda1/Microsoft/Boot/bootmgfw.efi 27d382c5fc21df6f4a75baed05aa1d9d sda1/Microsoft/Boot/bootmgr.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sdb : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes sda : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, has-win, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sdb6 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, not-far sdb2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sdb7 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sdb3 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sdb1 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda4 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda3 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
Partitions info (2/3): _________________________________________________________
sdb6 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb7 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb3 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot sda4 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot sda3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot sda1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
sdb6 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sdb sdb2 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb7 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sda4 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors Disk identifier: DF0979DF-6938-4836-BA9E-D2CDEBA30FF8 Start End Sectors Size Type sda1 2048 206847 204800 100M EFI System sda2 206848 239615 32768 16M Microsoft reserved sda3 239616 975705584 975465969 465.1G Microsoft basic data sda4 975706112 976771071 1064960 520M Windows recovery environment Disk sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors Disk identifier: 0x63f3bbb2 Boot Start End Sectors Size Id Type sdb1 * 2048 208844 206797 101M 7 HPFS/NTFS/exFAT sdb2 208848 6604580 6395733 3G 7 HPFS/NTFS/exFAT sdb3 614405928 1953525167 1339119240 638.5G 7 HPFS/NTFS/exFAT sdb4 6604798 614404095 607799298 289.8G 5 Extended sdb5 6604800 14604287 7999488 3.8G 82 Linux swap / Solaris sdb6 14606336 46604287 31997952 15.3G 83 Linux sdb7 46606336 614404095 567797760 270.7G 83 Linux Partition table entries are not in disk order.
parted -lm (filtered): _________________________________________________________
sda:500GB:scsi:512:512:gpt:ATA WDC WDS500G2B0A:; 1:1049kB:106MB:105MB:fat32:EFI system partition:boot, esp; 2:106MB:123MB:16.8MB::Microsoft reserved partition:msftres; 3:123MB:500GB:499GB:ntfs:Basic data partition:msftdata; 4:500GB:500GB:545MB:ntfs::hidden, diag; sdb:1000GB:scsi:512:4096:msdos:ATA TOSHIBA DT01ACA1:; 1:1049kB:107MB:106MB:ntfs::boot; 2:107MB:3382MB:3275MB:ntfs::; 4:3382MB:315GB:311GB:::; 5:3382MB:7477MB:4096MB:linux-swap(v1)::; 6:7478MB:23.9GB:16.4GB:ext4::; 7:23.9GB:315GB:291GB:ext2::; 3:315GB:1000GB:686GB:ntfs::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 vfat 128E-A4D9 711e7e9d-b91f-4db3-afc3-20a6432f3c8c EFI system partition ├─sda2 e80b9080-42e7-4bc4-a76b-c9f1eee0f361 Microsoft reserved partition ├─sda3 ntfs 18328F59328F3B30 19d0a356-7f57-4eee-bb11-e114ab3840da Basic data partition └─sda4 ntfs E462908662905F5C 15c30c63-698b-4843-b354-01bf06ed4456
sdb
├─sdb1 ntfs 5A2034F12034D62B 63f3bbb2-01 Зарезервировано системой ├─sdb2 ntfs CC5A9AD95A9ABF9E 63f3bbb2-02 Новый том
├─sdb3 ntfs 447039BC7039B590 63f3bbb2-03
├─sdb4 63f3bbb2-04
├─sdb5 swap 39c16168-6904-4518-843e-0a4d3e588c0f 63f3bbb2-05
├─sdb6 ext4 8c1eacdf-ad06-471b-8500-a24e61e80775 63f3bbb2-06
└─sdb7 ext2 ab28032f-387c-498b-9774-18e3c3c7e044 63f3bbb2-07
Mount points (filtered): _______________________________________________________
                            Avail Use% Mounted on
/dev/sda1 64.9M 32% /mnt/boot-sav/sda1 /dev/sda3 309.8G 33% /mnt/boot-sav/sda3 /dev/sda4 88.6M 83% /mnt/boot-sav/sda4 /dev/sdb1 74M 27% /mnt/boot-sav/sdb1 /dev/sdb2 3G 3% /mnt/boot-sav/sdb2 /dev/sdb3 331.1G 48% /mnt/boot-sav/sdb3 /dev/sdb6 1.2G 87% / /dev/sdb7 247G 2% /home
Mount options (filtered): ______________________________________________________
===================== sda1/efi/ubuntu/grub.cfg (filtered) ======================
search.fs_uuid 8c1eacdf-ad06-471b-8500-a24e61e80775 root hd1,msdos6 set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg
====================== sdb6/boot/grub/grub.cfg (filtered) ======================
Ubuntu 8c1eacdf-ad06-471b-8500-a24e61e80775 Ubuntu, with Linux 5.19.0-38-generic 8c1eacdf-ad06-471b-8500-a24e61e80775 Ubuntu, with Linux 5.19.0-32-generic 8c1eacdf-ad06-471b-8500-a24e61e80775 Windows 7 (on sdb1) 5A2034F12034D62B
END /etc/grub.d/30_os-prober
END /etc/grub.d/30_uefi-firmware
========================== sdb6/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sdb6 during installation
UUID=8c1eacdf-ad06-471b-8500-a24e61e80775 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
UUID=128E-A4D9 /boot/efi vfat umask=0077 0 1
/home was on /dev/sdb7 during installation
UUID=ab28032f-387c-498b-9774-18e3c3c7e044 /home ext2 defaults 0 2
swap was on /dev/sdb5 during installation
UUID=39c16168-6904-4518-843e-0a4d3e588c0f none swap sw 0 0
======================= sdb6/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
==================== sdb6: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
21.580150604 = 23.171510272 boot/grub/grub.cfg 1 13.568828583 = 14.569418752 boot/grub/i386-pc/core.img 1 13.601192474 = 14.604169216 boot/vmlinuz 1 12.171504974 = 13.069053952 boot/vmlinuz-5.19.0-32-generic 1 13.601192474 = 14.604169216 boot/vmlinuz-5.19.0-38-generic 1 12.171504974 = 13.069053952 boot/vmlinuz.old 1 18.837516785 = 20.226629632 boot/initrd.img 1 18.204616547 = 19.547058176 boot/initrd.img-5.19.0-32-generic 1 18.837516785 = 20.226629632 boot/initrd.img-5.19.0-38-generic 1 18.204616547 = 19.547058176 boot/initrd.img.old 1
===================== sdb6: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18683 Dec 2 18:18 10_linux -rwxr-xr-x 1 root root 43031 Dec 2 18:18 10_linux_zfs -rwxr-xr-x 1 root root 14180 Dec 2 18:18 20_linux_xen -rwxr-xr-x 1 root root 13369 Dec 2 18:18 30_os-prober -rwxr-xr-x 1 root root 1372 Dec 2 18:18 30_uefi-firmware -rwxr-xr-x 1 root root 700 Sep 20 2022 35_fwupd -rwxr-xr-x 1 root root 214 Dec 2 18:18 40_custom -rwxr-xr-x 1 root root 215 Dec 2 18:18 41_custom
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub-efi of sdb6, using the following options: sda1/boot/efi Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file
Blockers in case of suggested repair: __________________________________________
WindowsEFI detected. Please disable BIOS-compatibility/CSM/Legacy mode in your UEFI firmware, and use this software from a live-CD (or live-USB) that is compatible with UEFI booting mode. For example, use a live-USB of Boot-Repair-Disk-64bit (www.sourceforge.net/p/boot-repair-cd), after making sure your BIOS is set up to boot USB in EFI mode.
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Ubuntu 22.04.2 LTS entry (sda1/efi/**/grub.efi (** will be updated in the final message) file) ! If your computer reboots directly into Windows, try to change the boot order in your UEFI firmware. If your UEFI firmware does not allow to change the boot order, change the default boot entry of the Windows bootloader. For example you can boot into Windows, then type the following command in an admin command prompt: bcdedit /set {bootmgr} path \EFI**\grub.efi (** will be updated in the final message) The boot of your PC is in BIOS-compatibility/CSM/Legacy mode. You may want to retry after changing it to UEFI mode.
Edited: problem is solved at the moment, many thanks to oldfred and other expirienced users. I tried boot-repair through Ubuntu and throug liveUSB booting - it gives me wrong old Win 7 boot entry. Then I disabled Legacy mode, boot Ubuntu, update GRUB and it finds the required Win 10 boot entry.
ksolo0203
Problem is solved at the moment, many thanks to oldfred and other expirienced users. I tried boot-repair through Ubuntu and throug liveUSB booting - it gives me wrong old Win 7 boot entry. Then I disabled Legacy mode, boot Ubuntu, update GRUB and it finds the required Win 10 boot entry.
ksolo0203
