I have performed a full-disk install of Ubuntu 22.04 on an old MacBook Pro (MacBookPro5,2 from 2009, Core 2 Duo) machine completely wiping OS X in the process.
I'm now facing the known issue of the 30-second white screen delay on boot. I already figured out I have to use the OS X bless command to set Ubuntu as the boot partition. My question is what command-line arguments do I have to pass exactly? All examples on the internet make use of the --legacy option and talk about BIOS mode, but from what I could figure out my Ubuntu installation is using EFI (the /sys/firmware/efi directory exists).
Am I right in assuming then that I shouldn't use the --legacy option when blessing the partition? Also which partition do I have to bless? The /dev/sda1 one?
Here's the output of df -h when run in Ubuntu:
t30@macbook:~$ df -h
tmpfs 770M 1,7M 768M 1% /run
/dev/sda2 457G 12G 423G 3% /
tmpfs 3,8G 0 3,8G 0% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
/dev/sda1 511M 6,1M 505M 2% /boot/efi
tmpfs 770M 52K 770M 1% /run/user/1000
So would I just invoke bless like this (replacing /dev/sda1 with whatever it's mounted as under bless)?
bless --device /dev/sda1 --setBoot
So after trying out different variations, here are the results:
bless --device /dev/disk0s1 --setBoot
doesn't appear to do anything. Still long timeout on white screen. System still booting afterwards.
bless --device /dev/disk0s2 --setBoot same as above.
bless --device /dev/disk0s1 --setBoot --legacy still long timeout on white screen. After that system goes to black screen and won't boot into Ubuntu.
There are only /dev/disk0s1 and /dev/disk0s2 listed in fdisk for /dev/disk0. I'm assuming /dev/disk0s1 is /boot/efi, but I have no idea.
