I just installed StackApplet StackApplet 1.5 using the debian package from the launchpad site. When I first clicked on the preferences button in the menu it tried opening http://localhost:8150/ in Chromium, and I got this error:
This webpage is not available The webpage at http://localhost:8150/ might be temporarily down or it may have moved permanently to a new web address.
Error 120 (net::ERR_SOCKS_CONNECTION_FAILED): Unknown error.
My Chromium is launched with a switch to make it use a socks5 proxy, using this command:
chromium-browser  --proxy-server="socks5://localhost:1080" %U
I remembered that I wasn't using a bypass proxy URL list so I added the switch: --proxy-bypass-list="localhost,127.0.0.1" to the above command and I was then able to access the preference page without any problems.
However, after adding my account information I see the message: Network Error. in the StackApplet menu. This makes me think that StackApplet might be trying to use the socks5 proxy--even though it is not set globally, only Chromium uses this proxy. I don't require StacksApplet to use my proxy, in fact it would probably be better if it didn't. So my questions are:
  1. What does the Network Error. message mean?
    and
  2. What should I do to fix/debug this error?
adempewolff
  • 12,400
I am the author of StackApplet and I'll do my best to answer your question.
"...so I added the switch: --proxy-bypass-list="localhost,127.0.0.1" to the above command and I was then able to access the preference page without any problems."
I'm actually surprised that Chromium wouldn't display a local URL without the command-line argument specifying a proxy. Still - if it works, that's great.
"What does the Network Error. message mean?"
This error is displayed whenever the application receives a URLError exception from the urllib2 Python module. This can happen for a number of different reasons - including a misconfigured proxy.
"What should I do to fix/debug this error?"
This is tricky.
StackApplet isn't able to use either system-wide or Chromium-specific proxy settings. (In fact, being able to configure proxy settings for StackApplet has been a long-standing feature request.)
What I would suggest is running StackApplet in a terminal. Make sure that all running instances of the application are closed and run:
/usr/bin/stackapplet
Keep an eye out for any error messages that appear in the output.
If you continue to receive errors, please file a bug here.
Nathan Osman
  • 32,495
