The canonical method to mount encrypted volumes from the command line on later Ubuntu editions involves udisksctl. However, that recipe mounts the volume in read-only mode.
$ udisksctl unlock -b /dev/sdd1
Passphrase:
Unlocked /dev/sdd1 as /dev/dm-1.
$ ls -la /dev/mapper total 0 drwxr-xr-x 2 root root 100 apr 2 12:58 . drwxr-xr-x 20 root root 4860 apr 2 12:58 .. crw------- 1 root root 10, 236 mrt 28 19:27 control lrwxrwxrwx 1 root root 7 apr 2 12:58 luks-1841d2d1-4ce7-46e4-805e-0be262199e7d -> ../dm-1 lrwxrwxrwx 1 root root 7 apr 2 12:53 NOAB -> ../dm-0
$ udisksctl mount -b /dev/mapper/luks-1841d2d1-4ce7-46e4-805e-0be262199e7d Mounted /dev/dm-1 at /media/user/NOAB
$ cd /media/user/NOAB
$ touch test.txt touch: cannot touch 'test.txt': Read-only file system
Going through the udisksctl manual I understand it takes the same arguments as good old mount. So I gave it a try:
$ udisksctl unmount -b /dev/mapper/luks-1841d2d1-4ce7-46e4-805e-0be262199e7d
Unmounted /dev/dm-1.
$ udisksctl mount -o umask=0 -b /dev/mapper/luks-1841d2d1-4ce7-46e4-805e-0be262199e7d Error mounting /dev/dm-1: GDBus.Error:org.freedesktop.UDisks2.Error.OptionNotPermitted: Mount option `umask=0' is not allowed
Is there some other way of passing the umask argument to udisksctl? Or any other method to mount the volume in read and write mode?
This issue seems to be rooted with udisksctl, perhaps a limitation with this tool. The solution is to decrypt the volume with cryptsetup and mount directly with mount (log below). It also functions correctly mounting to the /media/user folder.
$ sudo cryptsetup open /dev/sdd1 NOABdev
Enter passphrase for /dev/sdd1:
$ mkdir -p ~/mount/test
$ sudo mount /dev/mapper/NOABdev ~/mount/test
$ touch ~/mount/test/test.txt
