I wanted to create partitions on a SD card. I tried to use GParted, KDE Partition Manager and also tried it under Windows using the system's manager but it always fails at creating more than one partition.
The Process starts normal but then fails at KDE Partition Manager and shows an error, it continues at GParted without error but in the end you can not find the partitions - they stay beeing undefinied space - Windows gives me the same struggle. The first partition all of these three are creating works perfectly fine, but then they all fail to create another one.
I have tried different formats: exFat, Fat32, NTFS, ext1,2,3,4 (encryption on and off). It's always the same result. I have tried creating partitions with all the same type of format and tried to use mixed ones.
Partition tables I used were MS-Dos as well as GPT.
I have played around with space before and after each partition - no result.
Is it in general a problem to partitionate a sd flash card ?
Edit: I've also tried fdisk - without success. It creates just the first partition, the rest doesn't work.
Thanks for all the replies so far. I used f3probe to find out that the card is damaged and further research brought up that I was delivered a fake sd card. It's not from the manufacturer that is printed on it. I wasn't considering that I actually was delivered a fake one.
