I'm trying to install the g++ compiler on Ubuntu 22.04.1 LTS, and I get the following:
$ sudo apt-get install g++
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help resolve the situation:
libc6-dev : Depends: libc6 (= 2.35-0ubuntu3) but 2.35-0ubuntu3.1 is to be installed
Running
$ dpkg --get-selections | grep hold
returns me nothing at all. I am new to Linux, so I have no idea what to do next.
Does anyone know how to resolve this issue?
Regards, -- DrB.
UPDATE 1: I tried
$ sudo apt install build-essential
but that gave me the exact same result.
UPDATE 2: I downgraded libc6 as follows:
$ sudo apt install libc6=2.35-0ubuntu3 libc-bin=2.35-0ubuntu3
after that, the command
worked just fine.
HOWEVER: notepadqq NO LONGER WORKS.
The question now is... how can I find out what else I broke by doing this?
