I checked partition for /tmp and it seems to be full.
>> df /tmp
Filesystem     1K-blocks     Used Available Use% Mounted on
/dev/sda2       23854928 23579092         0 100% /
Checking all the partitions gives this:
>> df -i
Filesystem       Inodes  IUsed    IFree IUse% Mounted on
tmpfs           2021460   1660  2019800    1% /run
/dev/sda2       1525920 398781  1127139   27% /
tmpfs           2021460    461  2020999    1% /dev/shm
tmpfs           2021460      4  2021456    1% /run/lock
/dev/nvme0n1p1        0      0        0     - /boot/efi
/dev/sda4      57524224 798172 56726052    2% /home
tmpfs            404292    269   404023    1% /run/user/1000
And another command, just for the root directory, gives this
>> sudo du -d 1 -h /
17M /etc
835M    /opt
4.0K    /mnt
24G /home
du: cannot access '/run/user/1000/doc': Permission denied
du: cannot access '/run/user/1000/gvfs': Permission denied
2.8M    /run
4.0K    /cdrom
0   /sys
462M    /boot
94M /root
16K /lost+found
4.0K    /srv
232K    /dev
392K    /tmp
9.7G    /var
12G /usr
du: cannot access '/proc/4678/task/4678/fd/46': No such file or directory
du: cannot read directory '/proc/1238545/task/1238545/net': Invalid argument
du: cannot read directory '/proc/1238545/net': Invalid argument
du: cannot access '/proc/1582983/task/1582983/fd/4': No such file or directory
du: cannot access '/proc/1582983/task/1582983/fdinfo/4': No such file or directory
du: cannot access '/proc/1582983/fd/3': No such file or directory
du: cannot access '/proc/1582983/fdinfo/3': No such file or directory
0   /proc
203M    /media
14G /snap
60G /
I am on Ubuntu 22.04, and can't figure out where and how I need to free up space. I really appreciate any help you can provide.
Max
  • 19
