I installed the newer kernel version linux-image-5.19.0-38-generic because of a key error related to installed packages with unmet dependencies. After the installation there was no Ethernet nor wireless connection available anymore.
So I downgraded to the older kernel version linux-image-5.19.0-35-generic. This did not change anything. In fact, I still get an error message related to installed packages with missing dependencies.
I tried to reinstall the network manager packager offline (with the sudo dpkg -i network-manager*.deb command) but dependency problems prevent the configuration of the Network Manager. E.g. neither the dependencies libndp0 nor the libteamdctl0 are installed.
How do I install the Network Manager with all its missing dependencies offline?
In general, I would appreciate every suggestion you have concerning the problem with installed packages with missing dependencies.
Thank you for your helpful advice. The solution for the problem with the Network Manager seem to be simpler than I thought. I just installed the missing packages listed below by the command line.
This was the output of the sudo dpkg -i network-manager*.deb command:
(Reading database ... 171577 files and directories currently installed.)
Preparing to unpack network-manager_1.36.4-2ubuntu1_amd64.deb ...
Unpacking network-manager (1.36.4-2ubuntu1) over (1.36.4-2ubuntu1) ...
dpkg: dependency problems prevent configuration of network-manager:
network-manager depends on libndp0 (>= 1.2); however:
 Package libndp0 is not installed.
network-manager depends on libnm0 (= 1.36.4-2ubuntu1); however:
Version of libnm0:amd64 on system is 1.36.6-0ubuntu2.
network-manager depends on libteamdctl0 (>= 1.9); however:
Package libteamdctl0 is not installed.
dpkg: error processing package network-manager (--install): dependency problems - leaving unconfigured Processing triggers for dbus (1.12.20-2ubuntu4.1) ... Processing triggers for man-db (2.10.2-1) ... Errors were encountered while processing: network-manager
However, if I try to boot the system with the newer kernel linux-image-5.19.0-38-generic I lose Ethernet and Wireless connection again, although the Network Manager was successfully installed.
