I installed Ubuntu 22.04 on my laptop Lenovo Legion s7 no dual boot only Linux. After installing the Nvidia drivers from Ubuntu Software & Update version NVIDIA driver metapackage from nvidia-driver-525 (proprietary)
After installing drivers and rebooting wifi adaptor and bluetooth not found, and touchpad is not working.
I tried to delete nvidia drivers, with sudo apt-get --purge remove "*nvidia*"
The biggest issue is that I can not update or upgrade anything because of lack of internet. I can not even use ethernet.
I can not even connect to internet sharing it via usb from phone. But the usb is working.
Troubleshooting:
ifconfig -a
Command 'ifconfig' not found, but can be installed with:
sudo apt install net-tools
sudo lshw -c network
[sudo] password for eadmin:
*-network UNCLAIMED
   description: Network controller
   product: Wi-Fi 6 AX200
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:02:00.0
   version: 1a
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix cap_list
   configuration: latency=0
   resources: memory:fd700000-fd703fff
rfkill list all - no output
lspci -nnk | grep Net
02:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
            Subsystem: Rivet Networks Killerâ„¢ Wi-Fi 6 AX1650x (AX200NGW) [1a56:1654]
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 048d:c967 Integrated Technology Express, Inc. ITE Device(8296)
Bus 003 Device 003: ID 04f2:b67d Chicony Electronics Co., Ltd Integrated Camera
Bus 003 Device 002: ID 09da:0025 A4Tech Co., Ltd. A4tech 2.4G Wireless Device
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 8564:1000 Transcend Information, Inc. JetFlash
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f3:0c4b Elan Microelectronics Corp. ELAN:Fingerprint
Bus 001 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
sudo dmesg | grep iwl - no output
sudo dmesg | grep wifi - no output
uname -r
5.19.0-38-generic
uname -a
Linux user 5.19.0-38-generic #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 17 21:16:15 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
What I've tried:
sudo rfkill unblock all
install drivers for Wi-Fi 6 AX200 following this guide https://itslinuxfoss.com/install-intel-wifi-6-ax200-driver/
How can I repair fix the issue?
Kracozebr
  • 111
