I am running tightvnc on Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-1031-aws x86_64):
$ vncserver :0 -geometry 1980x1080
New 'X' desktop is ip-172-31-14-62:0
Starting applications specified in /home/hc/.vnc/xstartup Log file is /home/hc/.vnc/ip-172-31-14-62:0.log $ ps aux | grep vnc hc 408153 0.0 0.0 14836 12448 pts/0 S 13:37 0:00 Xtightvnc :0 -desktop X -auth /home/hc/.Xauthority -geometry 1980x1080 -depth 24 -rfbwait 120000 -rfbauth /home/hc/.vnc/passwd -rfbport 5900 -fp /usr/share/fonts/X11/misc/,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/75dpi/,/usr/share/fonts/X11/100dpi/ -co /etc/X11/rgb hc 408163 0.0 0.0 7004 2196 pts/0 S+ 13:37 0:00 grep --color=auto vnc
However, I am getting a grey screen: enter image description here
I have tried this solution and this solution.
Here is my ~/.vnc/xstartup:
$ cat ~/.vnc/xstartup
#!/bin/sh
export XKL_XMODMAP_DISABLE=1 unset SESSION_MANAGER unset DBUS_SESSION_BUS_ADDRESS
[ -x /etc/vnc/xstartup ] && exec /etc/vnc/xstartup [ -r $HOME/.Xresources ] && xrdb $HOME/.Xresources xsetroot -solid grey vncconfig -iconic &
gnome-panel & gnome-settings-daemon & metacity & nautilus & gnome-terminal &
Here is tightvnc's log
28/03/23 13:44:01 Xvnc version TightVNC-1.3.10
28/03/23 13:44:01 Copyright (C) 2000-2009 TightVNC Group
28/03/23 13:44:01 Copyright (C) 1999 AT&T Laboratories Cambridge
28/03/23 13:44:01 All Rights Reserved.
28/03/23 13:44:01 See http://www.tightvnc.com/ for information on TightVNC
28/03/23 13:44:01 Desktop name 'X' (my_host:0)
28/03/23 13:44:01 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t
28/03/23 13:44:01 Listening for VNC connections on TCP port 5900
Font directory '/usr/share/fonts/X11/75dpi/' not found - ignoring
Font directory '/usr/share/fonts/X11/100dpi/' not found - ignoring
sh: 1: /home/hc/.vnc/xstartup: Permission denied
28/03/23 13:44:10 Got connection from client [client's ip] 28/03/23 13:44:10 Using protocol version 3.8
28/03/23 13:44:10 Got connection from client [some hacker's IP] 28/03/23 13:44:10 (other clients [client's ip]) 28/03/23 13:44:10 Using protocol version 3.3 28/03/23 13:44:10 rfbVncAuthProcessResponse: authentication failed from [some hacker's IP] 28/03/23 13:44:10 Client [some hacker's IP] gone 28/03/23 13:44:10 Statistics: 28/03/23 13:44:10 framebuffer updates 0, rectangles 0, bytes 0 28/03/23 13:44:15 Full-control authentication passed by [client's ip] 28/03/23 13:44:15 Pixel format for client [client's ip]: 28/03/23 13:44:15 32 bpp, depth 24, little endian 28/03/23 13:44:15 true colour: max r 255 g 255 b 255, shift r 16 g 8 b 0 28/03/23 13:44:15 no translation needed 28/03/23 13:44:15 Enabling X-style cursor updates for client [client's ip] 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -314 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -223 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -308 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -307 28/03/23 13:44:15 Enabling LastRect protocol extension for client [client's ip] 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -313 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding -312 28/03/23 13:44:15 Using tight encoding for client [client's ip] 28/03/23 13:44:15 rfbProcessClientNormalMessage: ignoring unknown encoding 16 28/03/23 13:44:15 Using image quality level 8 for client [client's ip]
======================== Update #1: Followed Saxtheowl's suggestion: Installed Tigervnc instead:
$ sudo apt install tigervnc-standalone-server tigervnc-xorg-extension tigervnc-viewer
Made xstartup executable:
$ chmod +x ~/.vnc/xstartup
$ ls -la | grep xstartup
-rwxrwxr-x  1 hc hc  371 Mar 29 12:02 xstartup
Forced a reinstall:
$ sudo apt --reinstall install gnome-session-flashback metacity
Updated xstartup:
$ cat xstartup
#!/bin/sh
export XKL_XMODMAP_DISABLE=1 export XDG_CURRENT_DESKTOP="GNOME-Flashback:Unity" export XDG_MENU_PREFIX="gnome-flashback-"
gnome-session --session=gnome-flashback-metacity --disable-acceleration-check &
But failed to start with display 0:
$ vncserver :0
A X11 server is already running for display :0 on machine ip-172-31-14-62.ap-northeast-2.compute.internal.
$ ps aux | grep vnc
hc          3233  0.0  0.0   7004  2324 pts/0    S+   12:13   0:00 grep --color=auto vnc
Started with display 1 but died immediately:
$ vncserver :1 -geometry 1980x1080 -localhost no
New Xtigervnc server 'my_host.ap-northeast-2.compute.internal:1 (hc)' on port 5901 for display :1. Use xtigervncviewer -SecurityTypes VncAuth,TLSVnc -passwd /home/hc/.vnc/passwd my_host.ap-northeast-2.compute.internal:1 to connect to the VNC server.
=================== tail /home/hc/.vnc/my_host.ap-northeast-2.compute.internal:5901.log ===================
Session startup via '/home/hc/.vnc/xstartup' cleanly exited too early (< 3 seconds)!
Maybe try something simple first, e.g., tigervncserver -xstartup /usr/bin/xterm The X session cleanly exited! Killing Xtigervnc process ID 2940... success!
HCSF
  • 181
Your problem come from incorrect permission or an outdated version of TightVNC.
Here is how to fix this:
first you can try to set the correct permission chmod +x ~/.vnc/xstartup
If that dont work get a better VNC like TigerVNC sudo apt install tigervnc-standalone-server tigervnc-xorg-extension tigervnc-viewer then create a new xstartup file nano ~/.vnc/xstartup put this inside:
#!/bin/sh
then chmod +x ~/.vnc/xstartup then kill any remaining VNC session vncserver -kill :0 then start a new VNC session vncserver :0 -geometry 1980x1080 -localhost no then you can try connecting to your VNC server with your VNC client
if that dont work reinstall the appropriate gnome package sudo apt install gnome-session-flashback metacity then restart the VNC it should work.
Saxtheowl
  • 2,394
  • 22
Found this other answer that explains the issue: https://askubuntu.com/a/1387849/1612342
Basically just remove & from the end of the last line of xstartup.
If RDP is an option for you, here is a tutorial that covers how to launch Ubuntu Desktop on EC2. Your screenshot is missing the ubuntu-session part, which here is shown how to solve it for RDS.
tuomastik
  • 109
Carlos B
  • 126
