I upgraded from Ubuntu 16.04 to 18.04.1 LTS unexpectedly using below commands,which should be 18.04.6 LTS
sudo apt-get update && sudo apt-get upgrade
sudo reboot
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:    18.04
Codename:   bionic
karel
  • 122,292
  • 133
  • 301
  • 332
focus zheng
  • 115
You should update and upgrade the package list respectively.sudo apt-get update and sudo apt-get upgrade and then you have to update the release to the latest point release by running the command sudo apt-get dist-upgrade.
You can even check the version of Ubuntu after whole process by running the command lsb_release -a.
WARNING :: It's important to backup your important data to avoid any data loss before upgrading your system.
