Ubuntu version is 22.04 LTS Desktop
My boot disk is /dev/sda, and it has three partitions.
Here are the relevant mounts:
~$ df -h
Filesystem                   Size  Used Avail Use% Mounted on
tmpfs                        762M   12M  751M   2% /run
/dev/mapper/ubuntu--vg-root  227G   64G  152G  30% /
tmpfs                        3.8G  546M  3.2G  15% /dev/shm
tmpfs                        5.0M  4.0K  5.0M   1% /run/lock
/dev/sda2                    235M  180M   43M  81% /boot
/dev/sda1                    487M  5.3M  481M   2% /boot/efi
/dev/sda3 is the partition that ubuntu--vg-root is on:
~$ sudo pvdisplay
  --- Physical volume ---
  PV Name               /dev/sda3
  VG Name               ubuntu-vg
  PV Size               <237.76 GiB / not usable 2.00 MiB
I have plenty of free space in /dev/sda3 (/) but it starts right after the way-too-small /dev/sda2 /boot partition.
I'm uncertain if I can shrink /dev/sda3 and the pv / lv by moving the start further back rather than the end of that partition forward, but that seems like what I should do here. The other problem is I have no idea how to go about doing this. Probably a live cd and some full-fledged partition manager that can work with lvm volumes but I'm getting conflicting information about the best way to go about doing that in 2023.
If I can't do that, what are some other options I have available here? Would it be straightforward to move /boot right into the main / partition? Even if this is possible, is it a good idea?
Note that this isn't the same as "Increase partition size on which Ubuntu is installed?" because my / partition is fine. The only problem is my /boot partition is too small, and the tricky part is it's sandwiched in between two other partitions, the latter of which is LVM.
The suggested answers on the question of 'how to shrink my lvm volume' don't include any examples where the shrinking occurs by moving the front of the partition forward so there's more space in front of the LVM volume.
Any help would be appreciated, thank you!
tamale
  • 1,459
