In Ubuntu 22.04 after installing Qt6 using
sudo apt install qt6-base-dev
calling qmake results in an error message:
qmake: could not find a Qt installation of ''
or
qmake: could not exec '/usr/lib/qt5/bin/qmake': No such file or directory
It is however possible to call/run qmake6. How to make qmake work and point it to qmake6?
d99kris
  • 496
In Ubuntu 22.04 there is currently an open bug QtChooser doesnt support qt6.
So even if Qt6 has been installed using sudo apt install qt6-base-dev, qtchooser -l does not list a qt6 option and qmake outputs qmake: could not find a Qt installation of ''.
Assuming Qt6 is installed and qmake6 can be called, I believe there are two options:
1. Select Qt6 system-wide
Generate qt6.conf based on the path to qmake6
qtchooser -install qt6 $(which qmake6)
Move qt6.conf to system-wide dir
sudo mv ~/.config/qtchooser/qt6.conf /usr/share/qtchooser/qt6.conf
Set Qt6 as default option
sudo mkdir -p /usr/lib/$(uname -p)-linux-gnu/qt-default/qtchooser
sudo ln -n /usr/share/qtchooser/qt6.conf /usr/lib/$(uname -p)-linux-gnu/qt-default/qtchooser/default.conf
2. Select Qt6 for current user only
Generate qt6.conf based on path to qmake6
Select Qt6 as default (place in ~/.bashrc for persistence):
export QT_SELECT=qt6
d99kris
  • 496
