I was trying to install wine in my system but I removed it and installed it again because I had too much files and directories ant then I got this error when I install it using apt.
ninjmango@lenovothinkpadt400:~$ sudo apt install --install-recommends winehq-stable
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
winehq-stable : Depends: wine-stable (= 8.0.0.0~focal-1)
Does anyone know how to fix this? This might have to do with the installation candidate of all packages. Thank you for your support.
