I am trying to update packages on Ubuntu server 22.10 which is running on a Raspberry Pi 4B, that is being used as a remote server. There is no error in the DNS I tried ping google.com and it is working properly.
--- google.com ping statistics --- 9 packets transmitted, 9 received, 0% packet loss, time 8013ms rtt min/avg/max/mdev = 6.560/6.795/6.941/0.126
I'm not sure about my UFW firewall port. And do let me know if there's been any mistake in opening or closing any ports.
ufw firewall status
root@ubuntu:~# sudo ufw status
Status: active
To Action From
10000 ALLOW Anywhere
22/tcp ALLOW Anywhere
80/tcp ALLOW Anywhere
443 ALLOW Anywhere
80 ALLOW Anywhere
53 ALLOW Anywhere
443/tcp ALLOW Anywhere
9200 ALLOW Anywhere
10000 (v6) ALLOW Anywhere (v6)
22/tcp (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
53 (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
9200 (v6) ALLOW Anywhere (v6)
Error that it's showing
root@ubuntu:~# sudo apt-get update
Ign:1 http://download.opensuse.org/repositories/isv:/ownCloud:/server:/10/Ubuntu_21.10  InRelease
Ign:2 http://ports.ubuntu.com/ubuntu-ports kinetic InRelease
Ign:3 https://ppa.launchpadcontent.net/ondrej/php/ubuntu kinetic InRelease
Ign:4 http://ports.ubuntu.com/ubuntu-ports kinetic-updates InRelease
Ign:5 http://ports.ubuntu.com/ubuntu-ports kinetic-backports InRelease
Ign:6 http://ports.ubuntu.com/ubuntu-ports kinetic-security InRelease
Err:1 http://download.opensuse.org/repositories/isv:/ownCloud:/server:/10/Ubuntu_21.10  InRelease
  Temporary failure resolving 'proxyserver'
Err:2 http://ports.ubuntu.com/ubuntu-ports kinetic InRelease
Err:3 https://ppa.launchpadcontent.net/ondrej/php/ubuntu kinetic InRelease
Err:4 http://ports.ubuntu.com/ubuntu-ports kinetic-updates InRelease
Err:5 http://ports.ubuntu.com/ubuntu-ports kinetic-backports InRelease
Err:6 http://ports.ubuntu.com/ubuntu-ports kinetic-security InRelease
Reading package lists... Done
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/kinetic/InRelease  Temporary failure resolving 'proxyserver'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/kinetic-updates/InRelease  Temporary failure resolving 'proxyserver'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/kinetic-backports/InRelease  Temporary failure resolving 'proxyserver'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/kinetic-security/InRelease  Temporary failure resolving 'proxyserver'
W: Failed to fetch http://download.opensuse.org/repositories/isv:/ownCloud:/server:/10/Ubuntu_21.10/InRelease  Temporary failure resolving 'proxyserver'
W: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/dists/kinetic/InRelease  Temporary failure resolving 'proxyserver'
W: Some index files failed to download. They have been ignored, or old ones used instead.
No proxy server is created which has been checked by using this code of lines
echo "$http_proxy"
echo "$https_proxy"
env | grep proxy
All the above shows no output, and nothing is there even in sudo nano /etc/apt/apt.conf.
I want to get it back to the normal way it used to get updated and upgraded, and I want to delete unwanted UFW ports, which can be harmful for the server's security.
Edit:::::: For further discussion and solution please check https://ubuntuforums.org/showthread.php?t=2484973&p=14136226#post14136226
