I have installed allure on the ubuntu:
sudo apt-get update
sudo apt-get install allure
install allure command end with:
... Unpacking allure (0.5.0.0-1) ... Setting up libgtk2.0-common (2.24.32-1ubuntu1) ...
Setting up libgtk2.0-0:amd64 (2.24.32-1ubuntu1) ...
Setting up libgail18:amd64 (2.24.32-1ubuntu1) ...
Setting up libgail-common:amd64 (2.24.32-1ubuntu1) ...
Setting up allure (0.5.0.0-1) ...
Setting up libgtk2.0-bin (2.24.32-1ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
So, it seems allure installed successfully
Now I try to verify allure:
allure --version:
allure: command not found
Also I do not found allure in /usr/bin/allure - not exist
Also I try to search 'allure/bin' folder in the system:
find / -name allure/bin -type d 2>/dev/null
empty result.
So.
How to found allure?
The command dpkg-query -L allure, should list all files that are part of that package.
The executable is called Allure (notice the upper case A).
pLumo
  • 27,991
