grapejuice : Depends: python3 (>= 3.7~) but 3.6.7-1~18.04 is to be installed
I was all fine about python3 dependency as needed but at the end, I encountered this error.
Does anyone know how to fix this? This may have to do with the ppa repository or python. I should get an answer to this as a solution.
