I have two servers running ubuntu 22.04.2 LTS with openssh-server 1:8.9p1-3ubuntu0.1 installed. And on both servers I have installed the same admin user.
I want to test the legacy superdaemon xinetd for ssh. So I stopped the ssh.service on the first server and started the xinetd.service on that server after adding the following config file:
cat /etc/xinetd.d/ssh
service ssh { disable = no socket_type = stream protocol = tcp wait = no user = root server =/usr/sbin/sshd server_args = -1 flags = IPv4 interface = 192.168.50.100 }
When I try to ssh into the server running xinetd, the xinetd daemon should start the ssh daemon on the target server and allow me in. But I get the following error message:
ssh -v 192.168.50.100
OpenSSH_8.9p1 Ubuntu-3ubuntu0.1, OpenSSL 3.0.2 15 Mar 2022 debug1: Reading configuration data /etc/ssh/ssh_config debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/.conf matched no files debug1: /etc/ssh/ssh_config line 21: Applying options for debug1: Connecting to 192.168.50.100 [192.168.50.100] port 22. debug1: Connection established. debug1: identity file /home/thomasgrusz/.ssh/id_rsa type -1 debug1: identity file /home/thomasgrusz/.ssh/id_rsa-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ecdsa type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ecdsa-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ecdsa_sk type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ecdsa_sk-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ed25519 type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ed25519-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ed25519_sk type -1 debug1: identity file /home/thomasgrusz/.ssh/id_ed25519_sk-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_xmss type -1 debug1: identity file /home/thomasgrusz/.ssh/id_xmss-cert type -1 debug1: identity file /home/thomasgrusz/.ssh/id_dsa type -1 debug1: identity file /home/thomasgrusz/.ssh/id_dsa-cert type -1 debug1: Local version string SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.1 debug1: kex_exchange_identification: banner line 0: unknown option -- 1 kex_exchange_identification: read: Connection reset by peer Connection reset by 192.168.50.100 port 22
Any ideas?
karel
  • 122,292
  • 133
  • 301
  • 332
Use
server_args = -i
for xinetd.
Freddy
  • 161
Update: March 12, 2023
I found the issue when I looked into the error logs of the xindetd daemon on the target server. It throws the following error when I try to ssh in:
Mar 12 14:09:06 ubuntuserver100 sshd[1551]: fatal: Missing privilege separation directory: /run/sshd
I created the /run/sshd/ directory manually and then everything worked perfectly. This is a temp folder though, so it will be missing again after reboot. I fixed this by adding the following file:
thomasgrusz@ubuntuserver100:~$ cat /usr/lib/tmpfiles.d/sshd.conf
d /run/sshd 0755 root root
I got the idea from this post, but there is probably a more elegant solution for this.
Does anyone know, why this folder is missing in the first place?
karel
  • 122,292
  • 133
  • 301
  • 332
