I am trying to get my Mac Mini 2014 to boot Ubuntu 22.04 automatically. I am single booting, I have no use for OSX El Capitan, it's too old.
This Mac mini has a defective internal disk that can't is used, so am trying to install Ubuntu on two 2TB external USB disks.
I have managed to install Ubuntu by booting from a USB via Startup manager.
In short, if boot the machine with no interaction, I get the question mark icon and nothing boots, if I hold the option key startup manager presents me with an EFI Boot Icon that allows me to boot.
I have tried numerous options, but nothing works.
Last login: Thu Mar  9 22:36:11 2023 from 192.168.2.233
stephen@stephen-Macmini:~$ df -k
Filesystem      1K-blocks     Used  Available Use% Mounted on
tmpfs              801344     1984     799360   1% /run
/dev/sdb3      1849632920 10113548 1745489396   1% /
tmpfs             4006712        0    4006712   0% /dev/shm
tmpfs                5120        4       5116   1% /run/lock
/dev/sdc1      1921724608       28 1824032524   1% /opt
/dev/sdb2        47745772   186628   45101340   1% /boot
/dev/sdb1        24401200    10688   24390512   1% /boot/efi
tmpfs              801340       76     801264   1% /run/user/128
tmpfs              801340       68     801272   1% /run/user/1000
stephen@stephen-Macmini:~$ efibootmgr
BootCurrent: 0000
Timeout: 5 seconds
BootOrder: 0001,0000
Boot0000* ubuntu
Boot0001* rEFInd Boot Manager
  1. Dual boot OSX and Ubuntu - drops me into a Grub shell
  2. Installed refind, doesn't load.
  3. Tried boot-repair (which swapped the default EFI boot back to ubuntu) Boot repair log:
boot-repair-4ppa2056                                              [20230309_2330]
============================== Boot Info Summary ===============================
=> No boot loader is installed in the MBR of /dev/sda. => No boot loader is installed in the MBR of /dev/sdb. => No boot loader is installed in the MBR of /dev/sdc.
sda1: __________________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /EFI/refind/refind.conf /efi/BOOT/bkpbootx64.efi
                   /efi/BOOT/bootx64.efi /efi/BOOT/fbx64.efi
                   /efi/BOOT/mmx64.efi /efi/refind/refind_x64.efi
                   /efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi
                   /efi/ubuntu/shimx64.efi /efi/ubuntu/grub.cfg
                   /efi/refind/drivers_x64/ext4_x64.efi
sdb2: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:        /grub/grub.cfg /refind_linux.conf
sdb3: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 22.04.2 LTS
Boot files:        /etc/fstab /etc/default/grub
sdc1: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
================================ 1 OS detected =================================
OS#1: Ubuntu 22.04.2 LTS on sdb3
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: Haswell-ULT Integrated Graphics Controller from Intel Corporation BOOT_IMAGE of the installed session in use: /vmlinuz-5.19.0-35-generic root=UUID=80987750-5143-43f9-ba9f-2e9484719a72 ro quiet splash vt.handoff=7 df -Th / : /dev/sdb3 ext4 1.8T 9.7G 1.7T 1% /
===================================== UEFI =====================================
BIOS/UEFI firmware: 474.0.0.0.0(0.1) from Apple Inc. The firmware is EFI-compatible, and is set in EFI-mode for this installed-session. SecureBoot disabled - This system doesn't support Secure Boot. BootCurrent: 0000 Timeout: 5 seconds BootOrder: 0001,0000 Boot0000* ubuntu HD(1,GPT,177a4c8c-092d-49d1-8e2f-6c12d270bdb6,0x800,0x2e90800)/File(\EFI\ubuntu\shimx64.efi) Boot0001* rEFInd Boot Manager HD(1,GPT,177a4c8c-092d-49d1-8e2f-6c12d270bdb6,0x800,0x2e90800)/File(\EFI\refind\refind_x64.efi)
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sdb : is-GPT, no-BIOSboot, has---ESP, usb-disk, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes sdc : is-GPT, no-BIOSboot, has-noESP, usb-disk, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes sda : is-GPT, no-BIOSboot, has-noESP, not-usb, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sdb3 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios sdb2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, grubenv-ok, noupdategrub, not-far sdb1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sdc1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
sdb3 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdb1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sdc1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
sdb3 : not--sepboot, with-boot, fstab-has-goodBOOT, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sdb sdb2 : is---sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdb1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb sdc1 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdc sda1 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors Disk identifier: 69FFEE35-158D-45DB-B7AE-375F7C302D00 Start End Sectors Size Type sda1 2048 1953523711 1953521664 931.5G Linux filesystem Disk sdb: 1.82 TiB, 2000398933504 bytes, 3907029167 sectors Disk identifier: A893875B-4911-4A9F-813A-764D4781DA37 Start End Sectors Size Type sdb1 2048 48828415 48826368 23.3G EFI System sdb2 48828416 146485247 97656832 46.6G Linux filesystem sdb3 146485248 3907028991 3760543744 1.8T Linux filesystem Disk sdc: 1.82 TiB, 2000398933504 bytes, 3907029167 sectors Disk identifier: 2B13202B-160E-406C-B7F9-82355C51F56B Start End Sectors Size Type sdc1 2048 3907028991 3907026944 1.8T Linux filesystem
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:4096:gpt:ATA APPLE HDD HTS541:; 1:1049kB:1000GB:1000GB:::; sdb:2000GB:scsi:512:4096:gpt:Seagate Expansion HDD:; 1:1049kB:25.0GB:25.0GB:fat32::boot, esp; 2:25.0GB:75.0GB:50.0GB:ext4::; 3:75.0GB:2000GB:1925GB:ext4::; sdc:2000GB:scsi:512:4096:gpt:Seagate Expansion HDD:; 1:1049kB:2000GB:2000GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
└─sda1 d4140924-5c9d-43e6-83b2-10d3cacb899f
sdb
├─sdb1 vfat 8F51-453D 177a4c8c-092d-49d1-8e2f-6c12d270bdb6
├─sdb2 ext4 eed1593a-031d-49ee-ac0f-c34cdb51079d 054d946b-fa6a-4e92-a13c-de019ab978ba
└─sdb3 ext4 80987750-5143-43f9-ba9f-2e9484719a72 9fc9a23d-9cac-4cf6-8d6f-ddcf57de0d48
sdc
└─sdc1 ext4 f66d68d3-0076-4692-804d-e517ce13dd60 f78bae7e-578a-4dba-8d29-6dd0017ef115
Mount points (filtered): _______________________________________________________
                            Avail Use% Mounted on
/dev/sdb2 43G 0% /boot /dev/sdb3 1.6T 1% / /dev/sdc1 1.7T 0% /opt
Mount options (filtered): ______________________________________________________
==================== sdb1/EFI/refind/refind.conf (filtered) ====================
timeout 20 use_nvram false menuentry Linux { icon EFI/refind/icons/os_linux.png volume 904404F8-B481-440C-A1E3-11A5A954E601 loader bzImage-3.3.0-rc7 initrd initrd-3.3.0.img options "ro root=UUID=5f96cafa-e0a7-4057-b18f-fa709db5b837" disabled } menuentry "Arch Linux" { icon /EFI/refind/icons/os_arch.png volume "Arch Linux" loader /boot/vmlinuz-linux initrd /boot/initramfs-linux.img options "root=PARTUUID=5028fa50-0079-4c40-b240-abfaf28693ea rw add_efi_memmap" submenuentry "Boot using fallback initramfs" { initrd /boot/initramfs-linux-fallback.img } submenuentry "Boot to terminal" { add_options "systemd.unit=multi-user.target" } disabled } menuentry Ubuntu { loader /EFI/ubuntu/grubx64.efi icon /EFI/refind/icons/os_linux.png disabled } menuentry "ELILO" { loader \EFI\elilo\elilo.efi disabled } menuentry "Windows 7" { loader \EFI\Microsoft\Boot\bootmgfw.efi disabled } menuentry "Windows via shell script" { icon \EFI\refind\icons\os_win.png loader \EFI\tools\shell.efi options "fs0:\EFI\tools\launch_windows.nsh" disabled } menuentry "My macOS" { icon \EFI\refind\icons\os_mac.png volume "macOS boot" loader \System\Library\CoreServices\boot.efi disabled } menuentry "macOS via BootNext" { icon /EFI/refind/icons/os_mac.png firmware_bootnum 80 disabled }
===================== sdb1/efi/ubuntu/grub.cfg (filtered) ======================
search.fs_uuid eed1593a-031d-49ee-ac0f-c34cdb51079d root hd1,gpt2 set prefix=($root)'/grub' configfile $prefix/grub.cfg
======================== sdb2/grub/grub.cfg (filtered) =========================
Ubuntu 80987750-5143-43f9-ba9f-2e9484719a72 Ubuntu, with Linux 5.19.0-35-generic 80987750-5143-43f9-ba9f-2e9484719a72 Ubuntu, with Linux 5.19.0-32-generic 80987750-5143-43f9-ba9f-2e9484719a72
END /etc/grub.d/30_os-prober
END /etc/grub.d/30_uefi-firmware
====================== sdb2/refind_linux.conf (filtered) =======================
"Boot with standard options" "root=UUID=80987750-5143-43f9-ba9f-2e9484719a72 ro quiet splash vt.handoff=7" "Boot to single-user mode" "root=UUID=80987750-5143-43f9-ba9f-2e9484719a72 ro quiet splash vt.handoff=7 single" "Boot with minimal options" "ro root=UUID=80987750-5143-43f9-ba9f-2e9484719a72"
==================== sdb2: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
55.420860291 = 59.507695616 grub/grub.cfg 1 23.833614349 = 25.591148544 vmlinuz 1 23.431636810 = 25.159528448 vmlinuz-5.19.0-32-generic 2 23.833614349 = 25.591148544 vmlinuz-5.19.0-35-generic 1 23.431636810 = 25.159528448 vmlinuz.old 2 23.499778748 = 25.232695296 initrd.img 1 23.904014587 = 25.666740224 initrd.img-5.19.0-32-generic 1 23.499778748 = 25.232695296 initrd.img-5.19.0-35-generic 1 23.904014587 = 25.666740224 initrd.img.old 1
========================== sdb3/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sdb3 during installation
UUID=80987750-5143-43f9-ba9f-2e9484719a72 / ext4 errors=remount-ro 0 1
/boot was on /dev/sdb2 during installation
UUID=eed1593a-031d-49ee-ac0f-c34cdb51079d /boot ext4 defaults 0 2
/boot/efi was on /dev/sdb1 during installation
UUID=8F51-453D /boot/efi vfat umask=0077 0 1
/opt was on /dev/sdc1 during installation
UUID=f66d68d3-0076-4692-804d-e517ce13dd60 /opt ext4 defaults 0 2
======================= sdb3/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" GRUB_DISABLE_OS_PROBER=false
===================== sdb3: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18683 Dec 3 02:18 10_linux -rwxr-xr-x 1 root root 43031 Dec 3 02:18 10_linux_zfs -rwxr-xr-x 1 root root 14180 Dec 3 02:18 20_linux_xen -rwxr-xr-x 1 root root 13369 Dec 3 02:18 30_os-prober -rwxr-xr-x 1 root root 1372 Dec 3 02:18 30_uefi-firmware -rwxr-xr-x 1 root root 700 Sep 20 13:18 35_fwupd -rwxr-xr-x 1 root root 214 Dec 3 02:18 40_custom -rwxr-xr-x 1 root root 215 Dec 3 02:18 41_custom
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub-efi of sdb3, using the following options: sdb2/boot sdb1/boot/efi Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file restore-efi-backups
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Ubuntu 22.04.2 LTS entry (sdb1/efi/**/grub.efi (** will be updated in the final message) file) !
  1. Tried setting up an EFI partition on the faulty /dev/sda device
  2. Tried installing refind on MacOSX El Capitan (and Monterey)
I suspect very strongly that Mac's firmware really can't cope with not using the internal HD in any way (I have ordered an OWC upgrade kit to replace it).
If anyone has a solution or needs more info, please help.....
img1 enter image description here
Rishon_JR
  • 1,028
