I am reading the following procedure: How can I discover the hostnames for all the machines on my lan? .
However, when I tried the command avahi-browse -av -d local, it showed the followings, although many more computers (with avahi enabled) are connected in the local network.
Server version: avahi 0.8; Host name: mycomputer.local
E Ifce Prot Name                                          Type                 Domain
+ ZZZZZZZZZ IPv4 anothercomputer1 [XX:XX:XX:XX:XX:XX]     Workstation          local
+ ZZZZZZZZZ IPv4 anothercomputer2 [XX:XX:XX:XX:XX:XX]     Workstation          local
+ ZZZZZZZZZ IPv4 anothercomputer3 [XX:XX:XX:XX:XX:XX]     Workstation          local
: Cache exhausted
: All for now
In addition, I can connect computers that are not shown above via mDNS, for example, ssh anothercomputer10.local works.
How should I do to find all local computers via avahi?
H.Hiro
Hiro,
I had the same problem as you when using avahi-browse to search for a host on my LAN using mDNS. In my case it was a Raspberry Pi with avahi running. I could ping the Pi with ping raspberrypi.local successfully. I could even ssh with the local domain: ssh pi@raspberrypi.local.
When I ran avahi-browse initially I was getting a few different hosts on my network (media centres, TV boxes, etc.) but not the Raspberry Pi running Avahi.
The solution for me was to edit avahi-daemon.conf on the Pi and ensure this option is set to "yes":
[publish]
publish-workstation=yes
After saving that file I restarted the avahi daemon: sudo systemctl restart avahi-daemon
Now when I run avahi-browse on my PC to look for the Raspberry Pi I can see it in the results:
+ wlp4s0 IPv6 raspberrypi [xx:xx]               Workstation          local
+ wlp4s0 IPv4 raspberrypi [xx:xx]               Workstation          local
+ wlp4s0 IPv4 otherdevice                             Web Site             local
: Cache exhausted
: All for now
Apparently it is a privacy feature of avahi to have the workstation flag set to "no". I suppose it is like why some Bluetooth devices do not make themselves "discoverable".
I hope this helps.
A. Hed
