I'm setting up my old MacBook Pro as a Time Machine Server with ubuntu, and was wondering whether someone managed to do charge limiting on a Mac. This thread has some answers, none of them are Mac-specific though, and I believe this is a hardware-specific thing...
Thank you in advance!
I've accidentally solved this by setting a charge limit using bclm before installing Ubuntu. After the installation, the macOS partition is wiped, but the charge limit persists (in the MacBook's SMC) - at 80% capacity, Ubuntu tells me my battery is full and won't charge!
I can't change the charge limit anymore, but I want the laptop to run on the charger anyway ;)
Now let's hope the SMC doesn't get reset...
Have a look at this kernel module. It supports intel based macbook.
https://github.com/c---/applesmc-next
If applesmc-next is compatible and it works, you will be able to set threshold using command-line and gnome shell extension.
Command line
echo '60' > /sys/class/power_supply/BAT0/charge_control_end_threshold
Gnome shell extension Battery Health Charging
https://extensions.gnome.org/extension/5724/battery-health-charging/
Some information https://maniacx.github.io/Battery-Health-Charging/device-compatibility/apple-intel-series
Max
  • 106
