select-editor is a per user selector ... It helps you select your default sensible-editor from all installed editors ... It affects the file ~/.selected_editor i.e. for example on my system:
$ cat ~/.selected_editor
# Generated by /usr/bin/select-editor
SELECTED_EDITOR="/bin/nano"
Please see man select-editor:
select-editor provides a coherent mechanism for selecting and
storing a preferred sensible-editor on a per-user basis. It lists
the available editors on a system and interactively prompts
the user to select one. The results are stored as SELECTED_EDITOR
variable in ~/.selected_editor, which is sourced and used by
sensible-editor command. SELECTED_EDITOR variable is overridden by
the VISUAL and EDITOR environment variables.
update-alternatives, on the other hand, is a system-wide selector ... It helps you set the default behaviors e.g. editor that a system command calls ... visudo is such a command ... It does so by handling which editor /usr/bin/editor calls ... As a symbolic link i.e. for example on my system:
$ ls -l /usr/bin/editor /etc/alternatives/editor
lrwxrwxrwx 1 root root 9 Jan 8 2022 /etc/alternatives/editor -> /bin/nano
lrwxrwxrwx 1 root root 24 Jan 8 2022 /usr/bin/editor -> /etc/alternatives/editor
Please see man update-alternatives:
update-alternatives creates, removes, maintains and displays
information about the symbolic links comprising the Debian
alternatives system.
It is possible for several programs fulfilling the same or
similar functions to be installed on a single system at the
same time. For example, many systems have several text editors
installed at once. This gives choice to the users of a system,
allowing each to use a different editor, if desired, but makes it
difficult for a program to make a good choice for an editor to invoke
if the user has not specified a particular preference.
