i am unable to set up my canon lbp2900 printer on ubuntu12.04 64 bit i aliened the 64 bit rpm drivers and then installed the drivers (version 2.40) and followed the procedure in the canon guide ( however i changed fifo path to //localhost:59787 (somebody suggested) instead of 59687 (as suggested by canon guide) )
intially i got the message pstocapt failed .. the drivers had put the pstocapt and backend/ccp in the lib64 directory instead of the lib directory ... i copied that to the aproprite directory under lib
but still i get the error "ccp send_data error exit " i also tried with fifo path //localhost:59687
i also tried the Radu script but the drivers the script uses are version 1.90 and has conflicting packages
Jorge Castro
  • 73,717
For 12.04
Don't worry, for printing you have to enter the following everytime after fresh boot:
sudo modprobe usblp
ls -l /dev/usb/lp0
sudo ccpd start
It works for me with the 32-bit driver installed according to the community documentation.
