125
How can I compile a .java file?
What programs will I need? If I need the Java JDK I will also need help installing that. I'm very new to Ubuntu, so any program that I need to install I will need a tutorial on how to install them.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
user65407
  • 1,385
6 Answers6
141
To compile the file, open your terminal and type
javac filename.java
To run the generated class file, use
java filename
But to do this you need to have the Java JDK installed in your computer. You can install it with the instructions in How do I install Java?.
Raja G
  • 105,327
  • 107
  • 262
  • 331
32
OpenJDK works best for me. It's simple and I have never faced any problem with it. Just follow these simple steps:
  1. From Terminal install open jdk
    sudo apt-get install openjdk-7-jdk
  2. Write a java program and save the file as filename.java
  3. Now to compile use this command from the terminal
    javac filename.java
    If everything works well then a new "filename.class" file should be created.
  4. To run your program that you've just compiled type the command below in terminal:
    java filename
NOTE
You can use any text editor (like gedit) ,
replace the filename with watever name you want
you need to be on same directory as the "present working directory" (got by running pwd) while running the command from terminal.
842Mono
  • 10,070
Mrinal
  • 781
If for example your file is my_file.java:
class MyClass
    public static void main(String[] args)
       System.out.println("Hello World");
You want to do:
javac my_file.java
and then
java MyClass # The name of the class, not file
However, it is a common convention to give classes and files the same name.
muru
  • 207,228
Akavall
  • 647
You need to install a JDK, Java Development Kit. Ubuntu contains a metapackage default-jdk, which depends on currently prefered JDK. Now it is openjdk-6-jdk.
To compile a Java file to runnable .class file you can run
javac filename.java
and run it
java file
It is the most simple use-case and mostly it doesn't work because java classes mostly depends on other java classes placed in libraries.
So you would probably like to use some more sophisticated solutions. Most text editors supports Java syntax highlighting, for example jEdit, kate or vim, but they don't solve your compilation issue.
You have another option - you can install a full featured Java IDE. Ubuntu comes with both main OpenSource Java IDEs - NetBeans and Eclipse.
Seth
  • 59,332
Just type sudo apt-get update, followed by sudo apt-get install openjdk-7-jdk for a quick installation for java7, then you can play games with java :-)
For more detailed official Java documentation, please visit this link.
Fabby
  • 35,017
vicd
  • 511
Why is my output so weird when I try to compile a demo example with $ java my_program.java?
I found this program to compile at: [https://developers.google.com/optimization/introduction/java][1]
my_program.java:2: error: cannot find symbol
import com.google.ortools.Loader;
  symbol:   class Loader
my_program.java:3: error: cannot find symbol
import com.google.ortools.linearsolver.MPConstraint;
  symbol:   class MPConstraint
my_program.java:4: error: cannot find symbol
import com.google.ortools.linearsolver.MPObjective;
  symbol:   class MPObjective
my_program.java:5: error: cannot find symbol
import com.google.ortools.linearsolver.MPSolver;
  symbol:   class MPSolver
my_program.java:6: error: cannot find symbol
import com.google.ortools.linearsolver.MPVariable;
  symbol:   class MPVariable
my_program.java:11: error: cannot find symbol
    Loader.loadNativeLibraries();
  symbol:   variable Loader
my_program.java:13: error: cannot find symbol
    MPSolver solver = MPSolver.createSolver("GLOP");
  symbol:   variable MPSolver
my_program.java:16: error: cannot find symbol
    MPVariable x = solver.makeNumVar(0.0, 1.0, "x");
my_program.java:17: error: cannot find symbol
    MPVariable y = solver.makeNumVar(0.0, 2.0, "y");
my_program.java:22: error: cannot find symbol
    MPConstraint ct = solver.makeConstraint(0.0, 2.0, "ct");
my_program.java:29: error: cannot find symbol
    MPObjective objective = solver.objective();
12 errors
error: compilation failed
Rogonow
  • 101
