I have installed and set up Ubuntu Pro on my primary server and my backup server. However, I cannot get livepatch to enable on the backup server. I get the following error:
# sudo pro enable livepatch
One moment, checking your subscription first
Stderr: Could not retrieve client information.: GET request to "https://livepatch.canonical.com/v1/client/<machine-id>/info" failed
Stdout: Unable to enable Livepatch: Failed running command '/snap/bin/canonical-livepatch enable <REDACTED>' [exit(1)]. Message: Could not retrieve client information.: GET request to "https://livepatch.canonical.com/v1/client/<machine-id>/info" failed
The backup server does not have an external internet connection itself and instead has a proxy set up on the primary server which it uses (using tinyproxy). I have set up the proxy for environment, apt and snap. All other functions work fine, and esm-apps and esm-infra are enabled and working. But I can't figure out how to get livepatch enabled.
I tried following the instructions given in Can't enable Canonical Livepatch on Ubuntu 20.04.1 LTS, however, this did not resolve the problem.
What an I missing?
